I had an electrical shock and now when i put my air on cool it is blowing hot. I tried to rewire the thermostat to get through the weekend but forgot how to. any help. I have hot children
  • vennyboo1 May 16, 2009
    thanks, its actually central air and heat. Its a trane unit. I just played with the wires to see if i could get the cool air to come on and it did. I just hope i haven't done anything wrong that will cause a fire.
    what do you need from the trane to help. The thermostat is a luxpro psd111
  • 4,654 Answers
I will help you but I need to get the make and model number listed behind the front cover near base behind filter if a window unit.
Posted on May 16, 2009
  • John Tripp
    John Tripp May 16, 2009
    I will look up that model of thermostat. You be careful that you don't connect the wires wrong and burn out the thermostat. As far as the voltage I don't think you can cause other than a shock of 24 volts ac. Now under the house that becomes more powerful with you being between it and the ground.Email me and I will send you the wiring diagram in PDF format...Sea Breeze
    appliancepartsse@yahoo.com
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
I just purchased a honewell RTH 221 thermostat. I
Typically the four thermostat wires are:
R = power (or common)
G= FAN
W = Heat
Y = Cool
Assuming that you have a normal electric or gas furnace and air conditioning, if the heat really is coming on, then just switch the position of the the Yellow and White wires.
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
AC cools then blows hot air, tempature needle goes up & down
Sounds like the thermostat is trying to stick,and is causing the engine to over heat,therefore condenser is not cooling the freon down enough to cool.Have the thermostat changed and the cooling system bled out,this is most likely the cause.
Aug 29, 2009 | 2005 Lincoln LS
Our AC (Heat pump)is blowing hot air in the afternoons as the temperature outside rises. We have had the freon checked and it is okay. The AC will blow hot air for about 30 minutes then blow cool air. Our...
Your unit may be going into a defrost cycle. If so sounds like a bad defrost board. It sends a signal to electric heaters inside to come on. Change board and sensor
Jul 28, 2009 | Whirlwind FH-778 Air Conditioner
I had an electrical spark and now when i cut air on cool it blows hot air what do i do'' I tried to rewire my thermostat so i can get through the day with cold air, but forget how to do it
hope this helps well give the most common wire codes red go to the r terminal yellow makes the compressor come on y terminal green makes the fan come on g terminal white makes the heat come on for electric heat orange works the reversing valve on a heat pump it goes to the o terminal or b terminal if reversing valve energized in heating most go to o energized in cooling common blue or somtimes black take cover off indoor unit and check
May 16, 2009 | Heating & Cooling
Brand new goodman 2 and half ton package unit runing all the time
Sounds like the Thermostat or board is wired incorrectly(being new)
have the installer come back and rewire it.
Please rate this solution.
Jan 16, 2009 | Goodman CKL49AR49 Air Conditioner
My heat won't work! Air blows out, new thermostat
The hot water from your engine cooling system is not getting into the heater core. Check out the valve that admits water into it.
Aug 23, 2017 | 1995 Audi A6
A/c and heater
Is it leaking antefreeze?
The thermostat might be gone or needs a bigger thermostat
It could be a vaccum leak for the drivers side blowing cool air and the passenger side blowing warm air
Does it have dual air control switches one for drivers side and one for passengers side?
Oct 28, 2008 | 2003 Pontiac Grand Prix
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
