Question about Garmin EDGE 705
Garmin Edge 705 (just over 1 year old). Previously connected to computer fine (Found 2 removable drives when connected), and able to upload history etc, however now refuses to connect. When plugging in the Garmin, windows finds the additional SD card in the Garmin Edge, but claims the built in "disk" needs formatting. Have tried uninstall and reinstall of software, but no good.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Your disk might be corrupted. May be the only solution is to format, with all data lost.
Otherwise try to plugg another SD in Garmin, and see result.
Be carefull that when removing (disconnect) a SD device, it must be ejected properly, otherwise it may be corrupted if a write operation is ongoing.
Posted on Sep 04, 2010
Garmin 705 - device not found by Training Center
Garmin has moved everything to Garmin Connect. Depending on your device, Training Center may or may not be supported anymore. You can go to the link to read more on Garmin Connect. Also, Garmin now uses Garmin Express to sync and update devices. I'll attach the link. https://www.garmin.com/en-US/software/express
Aug 16, 2017 | Garmin EDGE 705
Hello, I own Garmin edge 705 I cannot turn it on when plugged to charger display shows battery icon close to empty (2 pixel line) and no charging is happening at all when connected to computer via...
Sounds like your battery has gone bad to me. I also own a garmin. I would suggest you contact garmin for repairs. You can go to their web site at www.garmin.com go to the top of the page where it says My garmin and log in to your account. If you don't have one then sign up for one its free. Then contact technical support either by email or by phone to get your unit repaired.
I hope this helps you out if it does please give me a YES on the web page you just received my response on. Thank you
Apr 13, 2011 | Garmin Edge 705 Handheld GPS Receiver
Cannot unlock the maps in my garminedge 705. When i turn unit on message comes up cannot unlock maps
Information on unlocking garmin maps can be found at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There's more information there than you need since the article is about garmin nuvi satnavs that display a message "No detailed maps found that support routing" but part of the article deals with locked maps. The principle is the same for the garmin Edge but you'll need to skip to the part that deals with unlocking maps.
Jan 02, 2011 | Garmin Edge 705 Handheld GPS Receiver
My garmin edge 305 will not upload my rides, the training center software stalls at 2% the declares an error.
I have similar problems that have only just started.
Together with Training Centre crashes after uploads forcing rollbacks by deleting a history tree file and using a backup...
Tres frustrating...
Am thinking seriously of ditching it...
Nov 29, 2010 | Garmin Edge 305 GPS Receiver
I have a garmin edge 705. Every week I ride the same course. When I compare the graph of this same course they do not coincide. The starting point elevation is not the same aldo I always start at the same...
The reason is linked to startup of the device probably. I have same issue.
2 ways to improve :
1/ Startup your device
You need to startup device, and wait automatic change of the screen to the ride mode, from the sattellite search screen.
You also can check you have more than 4 sattellites before starting a ride. Altitude can only be computed when at least 4 sattellites are synchronized. So start your device in the open air, not indoor, nor close to a building.
Garmin devices start automatically and have probably a smoothing function that make altitude converge to the reality slowly from a started erroneous capture.
2/ Upload your ride on Garmin connect site, then apply altitude fix algorithm proposed. This algorithm will fix the altitude of your waypoints, both fixing pure altitude start issue, and also fixing denivellation computation, which is erroneous because of cumulation of errors.
Hope this helps
Apr 12, 2010 | Garmin EDGE 705
Will the garmin edge 705 provide/ be able to produce a power watt measure during outdoor rides and what do i need to purchase to be able to get this information?
The 705 comes in multiple versions from basic that will give you heart rate to a team garmin version that has the cadence, speed, calories, etc. As for power meters the 705 is 3rd party compatible to show you watt measurements.
The following third-party ANT+Sport-enabled power meters are compatible with the Edge 705:
  • iBike
  • PowerTap
  • Quark
  • SRM
May 12, 2009 | Garmin EDGE 705
The cadence sensor will not sink to my edge 705
Please perform pairing as described in you user's manual. Device must be paired before becoming available.
http://www8.garmin.com/products/manual.jsp?product=010-00555-20
Apr 05, 2009 | Garmin EDGE 705
Date not changing
After my ride I needed to stop the timer and reset the device. Then connect to the computer and download the history. It appears that that information I was downloading was from a previous ride.
Jun 26, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 Uploading
You can configure the history hold duration. The user manual has simple explanation that you can browse at the link below
http://www8.garmin.com/manuals/967_OwnersManual.pdf
Similar issue I have encountered and I followed instruction on page 45, it resolved. Hope you will resolve the issue as well
Good Luck
Feb 08, 2008 | Garmin Edge 305HR GPS Receiver
Garmin EDGE 705 Logo
533 people viewed this question
Top Garmin Cycling Experts
SHARCNET-USA
SHARCNET-USA
perdue40
TO Lady
Are you a Garmin Cycling Expert? Answer questions, earn points and help others
