Question about Sony Televison & Video
****ghoasting aND RED pUSH(REDIS BRIGHT)ON A SONY KDL 32M3000
Please HELP i HAVE A SONY KDL 32M3000 THE PICTURE IS GHOASTING PICTURE LEAVES A SLOWMOTION EFFECT. ALso the Red is too bright like skin tones and red colored images. I tried changing picture settings but no fix.I have gone into service menu but I don't want to mess with that unless i get step by step instructions. How do u save setting in the service menu I tried ''mute'' button plus ''enter'' but nothing They told me it was either the signal board or the lcd. Im not an expert I doubt that beacuse I have heard other fixing the problem in the service menu. Anyone help will greatly be appreaciated I can even donate through paypal If somone helps with instruction and it fixes the problem. THanks my email is yave_d@yahoo.com
  • 8 more comments
  • yave_d May 16, 2009
    I haven't tried this suggestion but is there a possibility it might be the lcd display? this doesn't have anything to do does it? I want to hear other technicians if this is probably the cause what other suggestion mite other technicians have.
    Thanks guys this are all great ideas. I won't be able to try this till monday. Ill be trying to replug the t-con cables first and see if that works. I had another question the first soultion said that it might be the digital board. Is the Hdmi plug on the digital board? If it isn't cudn't I try plugging an hdmi and see if that works? Thanks I want to get as many soultion as possible
    yes i will try on monday beacuse i left it in my apartment at another city and I will go back on monday all of these solutions. So the hdmi isn not on the digital board is it? how do i rate the answers?
  • yave_d May 17, 2009
    ok hanks guys i will try this on monday. I ill keep posting on monday. First I'm going to try the reset. Then Im going to try the hdmi plug to see if pictures comes out good. If it does then I will try replugging the "t" cable. hopefully that works. If it doesn't I will replace the digital board. The tv is a sony kdml 32m3000. Bye I will be back monday
  • yave_d May 19, 2009
    hopefully it is not the lcd.I tried the hard reset. but the numbers in the the service menu still remain the same. Does anyone know how the save the new changes I make in the service menu. I have a picture of the values that were before I changed them. I did the automatic caliberation. BUt I change the values back to what they were but the don't save. I tried "mute" plus "enter" but doesnt save. I tried replugin the t-cone cable but still same problem. I havn't tried the hdmi. I order the digital board today. I just don't know how to save my changes on the service menu to caliberate the way it was. I know the values but they won't save? any help?
    i think thats for other sonys isnt it beacuse i press "display" "5" "volume up" then turn on
    i am able to change the caliberation values to my old setting i wrote them down but im not able to save them. help in how to save them
    Hey so its not the digital board like others say? How would you be able to tell if its the lcd panel? is it beacuse the settings don't save? WOuld you recommend me changing the signal board(digital bord)? I already ordered the part...
    I tryied factory default. How would I be able to change the herts? im not familiar with that.
    heres a picture at the bottom of this website http://www.avsforum.com/avs-vb/showthrea...
    thats what i see when i go into the service menus. my number look different beacuse i did auto caliberation. I change it to look like the picture but the numbers wont save
    Thanks i got the manual and a also purchase a service manual. It doesn't say anything about saving service menu it just tlls you how to get to it. the service manual will be in handy when changing the digital or bm board. hopefully it arrives by friday. I still can figure out how to save the settings for what you say is the RGB
  • yave_d May 27, 2009
    help. I replaced the bm board but I still have the same problem... what can be wrong
  • 10,594 Answers
Please check LCD Controller board (T-Con board) as mentioned in below image. Recheck / reinsert LVDS cable plugged with T-Con board.
Thanks.
Posted on May 16, 2009
  • 916 Answers
These model flat panel television have a slow motion mode
Check the manual and make sure this setting is turned off
Posted on May 19, 2009
  • 431 Answers
Hi My name is Vortash I have just seen the picture on the website link you posted and I beleive those settings are RGB and picture .. Brightness, contrast , and Hue depending on which tube you have installed .. the VGA setting is for the RGB setting to the scart .. I have tried to find how to save but to no avail and I have never actually worked on one of these sets before , to that end I thought it might be advantageous to you if you had a user manual didn't know if you actually had one but thought it couldnt hurt so have sent you one to your email you will need adobe to read it it is in PDF format .. I also located a Service manual that should tell you all you need to know it is available from manual zone a download at $15.. normally these manuals cost 3 times that so this is a bargain .. hope this helps regards Vortash
    Sergeant:
    Champion:
  • 201 Answers
Hi there
PLease try these steps:
  1. Check in your tv setup for any fabrick default
  2. check if there in setup for a seting called colour tempreture
  3. check for your a setting hertz and try between 50pp 60pp 120pp
Hope this helps
  • 110 Answers
You have a bad LCD Panel there are no menu setting that will repair this unit.
  • TOM2-TOM2
    TOM2-TOM2 May 19, 2009
    Sony has a one (1) year limited warranty on this unit. You will need a purchase receipt or bill of sale. To obtain warraty service call 800-222-7669. Sony knows about this problem don't let them off the hook make them stand behind what they sell. Give them the info you posted "The picture is ghoasting pictue leaves a slowmotion effect". very good description good job! and good luck!
  • TOM2-TOM2
    If you have ordered the digital PCB give it a try. I'm only trying to work with the information you give and I think it's the panel.
    President:
  • 1,197 Answers
Like most new sony's there is nothing you can do in the service menu other than do a reset....if you really have to see for yourself  press the following buttons in order
left,right,mute,center button,mute,menu
good luck
  • SAM JAYANTH CHANDRASEKAR
    The best advice is to not screw around in the service menu and simply
    deal with the aggressive reds by turning the COLOR control down
    slightly. Or, hire someone with the equipment and knowledge to properly
    calibrate your TV.
  • 483 Answers
Either the TCON board or the panel is bad. Sony supplies the two parts as a unit so you will have to have them replaced together. Hope it is under warranty because it is expensive ....
Lets see.
Good luck.
Fame
Posted on May 17, 2009
    Novelist:
  • 130 Answers
No the hdmi is not on the digital board.
and to rate just click the four blue dots that is called fixya.on your screen.
it will be rated.
keep updated with further queries.thanks.
  • bepositive May 27, 2009
    it needs to be checked by a professional at your place.this is some major fault.all the connections has to be checked 1 by 1 to locate the faulty.culprit part.
  • 3,741 Answers
Yes you can try plugging the hdmi and check.also keep us updated for further help. please do rate the solution.thanks.
  • 749 Answers
Hi, first try a 'hard reset' unplug your tv for 30 mins and try again this will 'reset' all the settings like the service menu settings.
If this does not work then you probably have a bad main digital video board. I would not suggest a person with prior electronics experience to perform this repair as the set holds extremely high voltages for hours after being turned off.
If you want to try it yourself, you can get the replacement part here
http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1016710-SONY&Click=17845
A service manual would come in handy when you are working on something like this. You may want to try searching for one before starting this repair.
My Sony KDL-32M3000 has ghost (dark red) display with slow motion picture. What could be the cause and how can it be repaired. Thanks
Thats usually caused by bad flex tab bonds on the LCD panel itself. If you search for flex tab issues vidoes it will show how the pisture can get slow motion in areass as well as double images in that area.
Dec 30, 2012 | Sony KDL-32M3000 32 in. LCD Television
Tv comes on then picture goes out but still has sound but no picture
Sounds like a back light failure. To verify this, turn on the set, dim the lights in room. Shine a bright flash light on the screen, if you see a faint picture on the screen, you have a back light failure. You either have a blown back lamp, 24v circuit fault, or a failed inverter board.
Dec 16, 2012 | Sony KDL-32M3000 32 in. LCD Television
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
Sony 32" LCD TV KDL-32M3000. No picture, LED will
What does it do if you unhook the flat cables going from the tcon to the panel, does the blinking go away and do you have sound then?
Dec 10, 2017 | Sony KDL-32M3000 32 in. LCD Television
I have a Sony KDL-32M3000 LCD TV.. When I turn the tv on you can see the screen lite up with no kind of picture, Almost like a lite comes on then goes out the the lite comes on again with no picture but I...
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!!@#
Mar 25, 2011 | Sony KDL-32M3000 32 in. LCD Television
My Sony KDL-32M3000 has dark reddish picture, checked the ribbons around the frame they're ok, power supply is ok, Hi voltage board is ok, I'm guessing the main video processing board since I don't have a...
It will be either BM board (Video Processor board) or Tcon Board (top side of panel). I have similar problem...my TV turns on, lamps turns on (you can see them from back side panel holes) but just a dark blue picture appears with no image (like picture when external input is selected without signal), no OSD appears....some times I can heard audio (using Antena).
I'm thinking getting the BM board.
Dec 25, 2010 | Sony KDL-32M3000 32 in. LCD Television
Sony Bravia KDL-32M3000 Has sound, no picture, back-lights are on, red lines flickering across the screen which seems to prove there is video present. I'm thinking T-Con board. I ask this question because...
There is no way to really check a T con without a lot of test equipment, only thing that is serviceable on that board is the small fuse that is by the LVDS connector...
Dec 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a sony 32m3000 color is dark and red also
@circuitworld: You claim in your profile that you repair plasma and LCD TV's, but you just told someone with an LCD to replace the convergence IC's and linear buffers. First off, convergence IC's are in rear projection TV's not LCD's, and the buffer boards are in plasma's, again, not in LCD's
@gardenwc: Typically what you are experiencing is a bad video controller or an actual faulty panel, the latter of which is not cost effective to replace.
Nov 03, 2009 | Sony KDL-32M3000 32 in. LCD Television
Slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part: http://www.shopjimmy.com/catalog/product/view/id/169673/s/sony-a-1376-788-a-bm-board-for-kdl-32m3000/
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Dave
503-432-9904
Premium TV Tech
www.pleasefixitdave.com
pleasefixitdave@yahoo.com
Sep 23, 2009 | Sony KDL-32M3000 32 in. LCD Television
Televison & Video Logo
2,923 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
