Question about Canon S200X Ink-Jet InkJet Printer
Lexmark x4380 Printer
My Lexmark X4380 uses Lexmark No2 and No3 Print Cartridges
Does anyone know of compatible cartridges - these are very expensive
Ta
  • jbtommy May 21, 2009
    Thought so - its a bummer
    Problem Solver:
  • 5 Answers
Sorry... only the #2 & the #3 carts will work with your printer... no other cart will. this is the reason why lexmark printers are inexpensive... cuz their carts are expensive. call 1800 539 6275... thats lexmark store #... order carts on the phone.. it might work out cheaper that buying from a store
Posted on May 21, 2009
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
I have put compatable ink cartridges in my printer and a message comes up
Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. Not only that you might not get the print quality you expect from ink that is specially formulated by Lexmark but you'll never know if the cartridge will actually work with your printer or harm your printer.
I highly recommend that you replace your compatible cartridges with genuine Lexmark cartridges to get the best printing results.
Nov 14, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
My cartages do not wan't to work any way. And I do mnot want to buy anothers because are very expensive.
What are the cartridge versions that you inserted into the printer? Compatible cartridges for the Lexmark X2600 printer are 14/14A and 15/15A. Make sure you are using genuine Lexmark cartridges.
Try to remove both cartridges from the printer. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert your cartridges. Try to print again.
Jul 26, 2011 | Lexmark X2600 InkJet Printer
Can i use print cartridge 70 or 12A1970 for printer lexmark P3150
#70 cartridge is not compatible with the Lexmark P3150 printer. Compatible cartridges for your printer available in the Lexmark website at http://bit.ly/9DTsPt. Thanks.
Oct 13, 2010 | Lexmark P3150 All-In-One InkJet Printer
Hi, replaced ink cartridge on Lexmark X2470. Now it goes as far as the "print alignment page" and freezes. Will not print the alignment page or any other page for that matter. Thanks.
Hello. The ink cartridge may not be seated properly in the carrier. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer asks for the cartridges, reinsert the cartridges. Also, make sure you're using the compatible ink cartridges for the printer. Let it print the alignment page all the way without cancelling it to align the cartridges properly. Hope this helps.
Mar 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
Black cartrtidge is not compatible can you fix this?
Remove the incompatable cartridge and replace with a genuine Lexmark cartridge.
I know, the cartridges are expensive. They are also guaranteed to work.
Nov 02, 2009 | Lexmark X2650 All-In-One InkJet Printer
Is there a compatible ink cartridge for Versajette M400 printer?
Sam's Club sells print cartridges for the Versajette at a more reasonable price. I saw the ad sometime ago, so give it a try.
Jan 27, 2009 | G7 Productivity Systems VersaJette M400...
Lexmark T62 Error 32- Unsupported print cartridge
Hi Sue,
Firstly, switch on the printer without a cartridge inside. Put in the old cartridge and if you get the Error 32, it could be poor contact. Clean the contacts in the printer (contact with the chip on the cartridge). If you don't get Error 32, there could be a problem with the chip contacts on the new OEM Lexmark cartridge or a faulty chip. As for other brands or remanufactured cartridges, it could be compatible parts they used. The chip and toner wheel have to be compatible.
Good luck.
Dec 15, 2008 | Lexmark Optra T620 Laser Printer
Epson stylus cx4800 won't print
Hi, reason we sell epson printers are they are the cheapest to run, but they do get alot of problems with the print heads, if you change from using refill ink kits to compatible ink cartridges you would not have to reset the chip each time, otherwise you will have to change to a more expensive to run printer like the HP, or Lexmark, lexmark is the most expensive for cartridges but it has the print heads built into the cartridge and not the printer itsself, epson only have the chip on the cartridge.
You can use the refill kits on most HP & Lexmark without having to reset the cartridge all you need to do is refill it.
but for every 3 for example you may have to buy a new cartridge which will be more expensive, ie if you get lines through your print, as the print head will probably get blocked on cartrdige.
Happy New Year
John
Dec 10, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Ink Cartridge
Lexmark/Dell info
Before you buy a remanufactured Lexmark or Dell inkjet cartridge please carefully read and understand the following:
The more recent ranges of remanufactured colour Lexmark and Dell ink cartridges have been remarkably unreliable - the failure rate being massively higher than all other remanufactured goods we supply. Our remanufactured HP's, Canon, and older Lexmark/Dell ranges remain very reliable.
At seems almost certain the micro-electronics in these cartridges have been developed in the factory to ensure failure at a given point. THE MODELS MOST LIKELY TO CAUSE PROBLEMS ARE THE LEXMARK No1, No2, No3, No29, No33, No35 and No43, AND THE DELL MODELS TO FIT PRINTERS 922/924/942/944/962/964 and Dell printers sold in the last 12 months. For some reason the problems seem to be with colour cartridges - black units remain reliable.
On the reverse of a brand new Lexmark 29 colour cartridge box (in print so small it's almost impossible to read) it says: "THE PATENTED PRINT CARTRIDGE CONTAINED INSIDE IS LICENSED FOR A SINGLE USE ONLY AND IS DESIGNED TO STOP WORKING AFTER DELIVERING A CERTAIN AMOUNT OF INK. A VARIABLE AMOUNT OF INK WILL REMAIN IN THE CARTRIDGE WHEN REPLACEMENT IS REQUIRED." In plain English this means the cartridge will certainly fail - even when there is ink inside.
Although this is not printed on the boxes of certain other models, the high failure rate suggests similar technology is deployed. A perfectly good remanufactured cartridge can be installed, and used - albeit temporarily. Suddenly and without explanation, an error message "UNSUPPORTED CARTRIDGE" appears, and the cartridge refuses to work ever again. Most will almost certainly end up in landfill.
Jan 23, 2007 | Dell 924 All-in-One InkJet Printer
Canon S200X Ink-Jet InkJet Printer Logo
148 people viewed this question
old marine
old marine
