Question about Canon ES75 Camcorder
Sony ccd-fx310 will not accept tape
When I place a tape in the camera the tape won't go down. But when I take the out close the cover it works like it should and tape caddy goes down. I have tried several tapes with the same result.
  • 10,594 Answers
Sony Camcorder CCD-FX310 is an old model of 1993
Symptom shows that drum motor (video head motor) is either not rotating or rotating on slower speed. This error prevents camcorder to load tape and complete tape threading around video head.
Possible cause (and I'm sure this is the only cause) is leaky electrolytic capacitors in drum servo section and power supply area.
Click HERE to see electrolytic capacitor. These capacitors are surface mounted very hard to replace even by qualified camcorder tech because these are mounted so close to each other on main board and not possible to unsold / remove securely.
In my opinion, CCD-FX310 does not worth to repair. If you want to try it yourself, download service (repair) manual from Manual Zone for small fee and replace all electrolytic capacitors mounted on main board and power supply board.
Let me know if you need further info / help.
Thanks.
Posted on May 16, 2009
Sony video handycam ccd fx420
The take up spool is no longer working. Time for a new V8 machine.
Jun 10, 2017 | Video Cameras
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
I have a Sony Video8 Handycam CCD-FX340 NTSC. It will not accept a tape. I can hit the eject button and the tape mechanism will come up and pop open. If I close it without a tape, it will go back down....
This problem can be caused by condensation. Leave camera and tapes in a warm dry place for a day and try again. If that doesn't help, there may be a tape threading fault. This can be something as simple as a broken drive belt, but still will require professional attention.
Oct 28, 2010 | Sony Video Cameras
I have a Sony Handy CAM 8 CCD-FX310. It will eject, but when you place a cassette in the slot and gently push it closed, the top will not retract down. it makes a slight spinning noise and then ejects...
I had the same problem with a Sony FX410, not much different than a FX310. With my camera all i had to do was to push the top down with a gentle push, it would engage and play and record normal. Don't force it hard, just a light pressure to help the cradle down. Most of these Sony cameras are crappy when it comes to loading the tape, most if not all the Sony's i've had end up with this problem, no matter what model you have. I've taken my camera competely apart and could not find the problem for not pulling down the tape, don't know if it can be a sensor or what, i never could find anything broken or loose or misalign, i oiled all the joints and moving parts with a light dab of thin oil, it worked fine except for that darn cradle not pulling down the tape.
Another thing that causes this is when the tape is to tight? In other words the tape should have a slight **** in it, i once ran into this big problem when the tape would not load and the camera kept ejecting it over and over. It was when i tried a new tape that i noticed how well it loaded yet the other tape wouldn't load. So i pulled out the tape and poked that little hole on the back right below the left hand pick up reel, i then turned the reel with my finger and gave it some slack, not much just enough to see the tape a little loose. I then reloaded the tape and it worked like a charm, seems that if the tape if to tight the camera won't accept it as the reels need to adjust back and forth for a few seconds, its that wacky sound you hear when you load a tape, seems like it has to adjust the tention inside the take up reels. Hope this might help you some?
Oct 08, 2010 | Sony Video Cameras
Handycam CCD-TR618E Hi-8 Analog Camcorder: I have a Sony Handycam CCD-TR61. It has worked fin...
that is look to be the cassette in switch
located on the side of the cass housing
or a sensor ...
hope that will help and this kind of trouble
is easy to fix for experienced tech an hour max
hope you will find one
regards Alan
May 18, 2010 | Sony Handycam CCD-TR618E Camcorder
Sony CCD-FX310 Camcorder how to adjust tracking
Sony camcorders has no tracking control for user.
I think video head is dirty / clogged. Put good quality video head cleaning tape in camcorder and check.
Its almost 15 years old camcorder.
Jan 30, 2009 | Canon ES75 Camcorder
Sony ccd-fx310
My camera won't play back.  Occasionally, if I ffwd it will show the picture otherwise its a blank screen.  Any ideas?  I've tried cleaning the heads a few times now
Dec 04, 2007 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam CCD-FX310
Record in slow mo mode, then playback in fast forward mode ;) Problem solved. You'll see the video in normal speed.
Oct 20, 2007 | Sony Handycam CCD-TRV37 Camcorder
Camera won't accept tape
tape senors is bad or have a bad tape
Jul 31, 2007 | Sony Handycam CCD-TRV308 Camcorder
Canon ES75 Camcorder Logo
623 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
