Question about Recoton Advent Advent HT3251A TV
Hourglass distorion on sides of screen
I have an advent hdtv about 4 years old, just developed an hourglass shape distortion on the sides of the screen. any ideas or suggestions?
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Line of distorion (or picture shift) on screen
Same thing happened to me but it was my cox hdtv/dvr box, I exchanged it and it resolved the problem.
Jan 04, 2010 | Televison & Video
Loewe Xelos TV 7 years old - screen image has colla_psed at the sides so appears distorted viz )_( shape. Is it a write off?
look for an square transformer near the LOT,underneath the transofrmer there is a resistor that can be defect.Measure al capacitors in East West circuit for bad capacitance.
Jul 27, 2009 | Televison & Video
Screen on JVC TV distorted
There is an Aspect button on the Remote for the TV. This button will fix this problem.
Aspect function strectches the picture horizontally or vertically to get rid of black bars in some movies. Sometimes this is good....sometimes bad
May 19, 2009 | JVC Televison & Video
Our 37" Toshiba has developed a concave picture
This is called "pincushion distortion" and the circuit that is supposed to correct it is not working. This is often due to solder connections to some parts failing because of heat. It may also be caused by component failure. It is a problem that is not difficult to correct once the bad connections are repaired or parts replaced, and the cost of a repair would be far less than replacement cost.
Dec 16, 2008 | Toshiba 32AF43 32" TV
Hourglass shape on screen
you might tyr adjusting the eprom setting to correct the e/w pincushion fault,or call for service to adjust.
Nov 06, 2007 | RCA 32F531T 32" TV
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Televison & Video Logo
205 people viewed this question
Top Recoton Advent Televison & Video Experts
S. Gontko
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
