Question about Galaxy Radios DX 77HML Base CB Radio
Jumps frequency radio is in semi-truck,problem occurs more when radio is warm, sometimes a lite tap brings it back. Frequency jumps from 27 to 24 but anything is possible I am useing a counter a fc347
  • 3,230 Answers
There is a IC called (oscillator circuit), during warm-up it changes Frequency automatically. It means its the time to change that IC.
Good Luck...
Thanks
Posted on May 16, 2009
Adjust idle speed
Probably accelerator/fuel mix sensor? Check the codes at a parts store like Pep Boys, Should indicate the bad boys
Mar 20, 2014 | Saturn SW2 Cars & Trucks
What causes speedometer jumps up and down or not read until after you reach 40 mpg on 04 hyundia santa fe?
Is there anything after market installed in the car? Alarm, radio, mobile video? The speedometer works off of reading voltage, a coded signal. Sometimes if something is installed, it could pinch the wire, be tapped into the wrong wire. If that is the case, take back to get looked at. If that is not the case then you may need to see a mechanic.
Oct 18, 2012 | 2004 Hyundai Santa Fe
FC-347 causes radio's transmit frequency to jump around when plugged in.
I don't understand why anyone would want to install one of these when the radio already has one.
Jul 01, 2012 | Galaxy Radios Fc-347 Frequency Counter For...
Why is my radio off one channel sometimes 18 is 19, 23 is 24 and so on
your radio needs to looked at by a tech. It is off frequency and just might get worse.
May 19, 2012 | Cobra Radio Communications
Way over modulated on my cobra 19 dx iv
check the frequency,these radios are good for the money,but drift off frequency,try different channels and see if that helps
Mar 10, 2012 | Cobra 19 DX IV CB Radio
Galaxy dx 2547 base cb frequency drift problems
for upper ssb adjust L21 for 16.51250 mhz . adjust L22 for 16.50750 for lower ssb. you do have a frequency counter don't you ?
Jan 01, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
Hyundai HQP421SR will not power up, red power led lites press power button and green lites but no picture. press power button again but will not go to stant by mode, lite remains green.
This is a fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Sep 05, 2011 | Hyundai HQP421SR 42 in. EDTV-Ready Plasma...
Ranger 6300F25drifts off frequency after warm up
buy some mr.freeze and spray some in the pll area to see if it drifts back on frequency. once you have determined that take it to a tech and let him know what you did and he will fix it.
Dec 17, 2010 | Ranger RCI-6300F-25 CB Radio
Turn on ignition everything works but want start
sounds like a starter. if possible without getting hurt maimed or mutilated, try tapping on the starter (best done with a rod standing beside the car) while someone holds the key in the start position. if car starts (works about 50% of the time) it's the starter. otherwise, if all lites come on, radio works, etc but nothing when you turn the key, replace the starter
Jul 07, 2010 | 2001 Hyundai Sonata
Galaxy Radios DX 77HML Base CB Radio Logo
57 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
