Question about Dryers
Amana (LE8517W2) No heat
We have an Amana LE8517W2 that has no heat. We had the same problem in early march and had it repaired. He replaced the thermal fuse only. Since that time, the dryer hose has also been replaced. Yesterday the dryer stopped heating again. The drum spins and I can feel the air coming out the vent, but there is no heat and honestly, I'm not paying for a repair again since the part was under $10 and the rest of the bill was all labor. So I have two questions:
1) Should I replace the thermal fuse again?
2) Does this speak to a larger problem since this is the second time in just under 3 months?
Thanks.
  • Synnex May 17, 2009
    Thanks Mobilian. I am going to assume that the blower assembly was cleaned out since he took the vacuum and vacuumed up pretty much anything he saw in the bottom. The outlet tube in the back of the dryer, as well as all the way up through the lint trap inside the front door were all cleaned out as well and the entire duct leading to the outside vent was replaced as well. If you can tell me more about the blower assembly and where it is accessed from (front or back) then I can tell you if he cleaned it out.
  • Dryers Master
  • 8,220 Answers
You should inspect the filter hosing and blower assembly and replace the cycling thermostat mounted on the blower housing. Get rid of whatever is blocking your outside vent and causing the thermal overload.The dryer is getting too hot either because of a control malfunction or an air blockage. If your control thermostat is the 4 wire type (2 small 2 large wires) then it probably is bad.
I test them by using an electronic thermostat to gage the temp. It should at max not exceed 160F nor get below 100F during drying cycle. Perma press should be around 150
delicate 140.
Posted on May 16, 2009
Amana le8517w2 stopped tumbling: everything else works
Pull the back off and check the dryer drum drive belt and motor.
Dec 05, 2016 | Amana Dryers
Heat does not start first time ONLY early in thE MORNING
when you start heat it should be temp. diff, between outdoor & indoor at least 5 C to start , check control
Nov 08, 2013 | Amana PTH123B25AJ Heat Pump Air...
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have an Amana AGDS902WW stove/oven. The oven is not heating properly. Sometimes it takes a very long time to heat and others it will not heat up at all. Is the problem in the thermocouple? If so, where...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 07, 2010 | Amana AGDS902 Gas Kitchen Range
My amana dryer model is making screeching sound
Hi Peggy...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. BE REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 30, 2009 | Amana DLE330RAW Electric Dryer
My dryer is heating but my clothes are not getting dry
Check the lint filter. Ensure that the fan is working. If you do not find any other problem, then it is usually either the fan , a wiring problem, or the thermostat / dryness sensor shutting down heat too early.
Jul 14, 2009 | Amana Dryers
Amana (Whirlpool) LE8517W2 electric dryer doesn't heat & more...
yes you should replace your thermostat because the thermostat is what tells you heating element to shut down. They probably ckecked it for continuity and it seemed good but in reality it's not functioning properly. you seem to know about your dryer quite well so here's a site to go to and see about maybe replacing the entire heating unit check out items 1914 and 667745 at www.repairclinic.com/Appliance-Parts?s=t-LE8517W2-%3d%3d&z=100
Feb 22, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
340 people viewed this question
Top Dryers Experts
