Question about Garden
Engine/shaft stopped working. Need to fix Ryobi trimmer.
I was trimming grass with my Ryobi 2-cycle gas trimmer. The cutting attachment hit an exposed tree root. I heard a clunk. Its drive mechanism is obviously no longer connected to the drive shaft. The engine won't start. The cutting line freely rotates, and the starter engine cord as no resistance. There must be a shear pin on the shaft, but there is no instruction on what to do in the owners manual. How do I fix this?
Thanks, Dex
  • dexbrown May 17, 2009
    Thank you, Clyde. I'll try that.
    Dex
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
Posted on Apr 11, 2010
  • 137 Answers
Somewhere there is a shear pin that attaches the cutter head to the drive line, when you hit the tree you sheared off the pin (safety devise) . You need to locate it and replace it, be sure you use a manfactureres shear pin. Thn again there might not be a shear pi in that case you have probably ruined your trimmer. The best way to find out is to call your ryobi dealer tell him you have a Ryobi model so and so and ask if this model has a shear pin.
Posted on May 17, 2009
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Steps to run Ryobi RY34420 30cc 4-Cycle Gas Lawn Grass Weed Trimmer
This is the Cars and trucks section. You need an Expert for small engines to view this. Relist in a better catagory.
Aug 29, 2012 | Cars & Trucks
I own a Troy-Bilt 425cs string trimmer with multiple add-on attachments. The unit works fine for string trimming, brush cutting, and cultivating. However, it will not properly power my edger attachment. ...
The power edger attatchment may have a slightly different coupling size on it than the other attatchments. Also, do a good inspection of the power head unit's coupling at the EZ LINK connector. Maybe the head unit connector is getting hot over time, due to a lack of lube, and expanding internally, causing slippage in the connection to the edger attatchment. Inspect all that you can.
Sep 11, 2011 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Trimmer runs good but does not cut grass
I have had a similar problem with an edging attachment. The socket that fit onto the shaft was worn, and the shaft would just spin, creating a lot of heat right there, but very little movement, and it would completely stall when you tried to use it implement, even though the moter still ran just fine. The cure, I'm sorry to say, was to replace the implement.
Best regards, --W/D--
Aug 15, 2009 | Craftsman Convertible 25cc. Gas Line...
Garden Logo
654 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
