Question about Kenmore 62602 Electric Dryer
Something is rattling inside the dryer. How do i
Something is rattling inside the dryer. How do i open it up to check if some object is caught in there? it is a kenmore model 110 electric dryer.
  • Kenmore Master
  • 8,220 Answers
We have a dryer fin with something rattling around in it. Do the fins come off?
Need a model number for the dryer for a more definitive answer--usually you would have to open the top cover to expose the drum. Depending on the model dryer, some baffles(proper name) are screwed onto the drum, some have plastic tabs which must be carefully pushed in order to remove the baffle. Most likely, the rattling is caused by coins left in pockets--they won't damage the dryer but can be irritating to listen to. Front load washers are notorious for trapping coins in the baffles of the rotating baskets--and that is A VERY EXPENSIVE REPAIR if you want to have the coins or objects removed.
Aug 14, 2015 | Dryers
Small object caught inside dvd writer
Remove the drive. Use paper clip to open drawer. Turn every which way to get object out. Last resort take covers off.
Mar 31, 2014 | Samsung DVD Burner SATA Model SH-224BB -...
LG Dryer repairs making flapping sound, inside vent burning
you can take the back off and it shouldnt do harm but its strange that an object would get their. but it might be a rag or towel
Jun 05, 2012 | LG 7.3 cu. ft. Gas Steam Dryer
The tumbler makes a terrible noise - I'm sure it's just a coin or a screw rattling around in there. I can't figure out how to get inside to look around the tumbler to see what it may be. And once...
Open the door and look inside - yes, you can see everything inside the drum. Sometimes buttons, especially the metal ones on denim pants, can make a pretty good racket.
If you don't find any foreign objects inside the drum, and the dryer makes noise even when it's empty, it may be time to change the drum rollers or the belt tensioner pulley. It's also remotely possible that there's something batting about in the blower housing, but if that is the case, it would probably be a screw or something broken off of the ductwork, or the blower itself is loose on the shaft. Post back if you need instructions for checking the mechanism underneath the drum.
Nov 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Makes a humming nose when you press start
Gas Dryers may produce buzz when the solenoid opens. The valve clicks at the start of the heat cycle, start of ignition and when the burner turns off. The flame makes a low roaring sound.
Make sure nothing is loose inside the drum. Check all exposed screws, and make sure they are tight.
Make sure dryer is level on the floor, and that nothing is leaning against the dryer.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 18, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I have a LG dryer dle5977w and it has started making a rattling noise it is coming from the bottom left side by the lint fan does any one out there have a idea of what it might be
May be a small sock or dryer sheet caught in the blower wheel.
Remove filter and use a flashlight to see down the filter housing. You may be able to see item.
Rotate the drum each way by hand to help see item.
Remove with hooked wire hanger.
You may need a service call to remove object.
Jan 04, 2010 | LG DLE5977 Electric Dryer
Loud rattling noise, but dries ok
The drum of a dryer is supported b the front and back of the unit, spins on a felt gasket. Noise is coming from rollers or their is something stuck between drum and the felts. The pulley is a piece of springy metal with a plastic wheel on it, could also be worn. If you take off front of dryer, drum will come loose, check to see if something is stuck. Common for loose change to get jambed in felts. Also spin rollers and pulley to see if need to be replaced. I still think something is caught in felt.
Aug 17, 2009 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
222 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
