I need an led head for xante color laser 21 - Office Equipment & Supplies
  • 13,433 Answers
If you require a replacement part do you have details on that part? part number? more details on what you need? thanks.
Posted on May 16, 2009
Magenta Stained product on a Xante Ilumina
i want to ask few question, are you using correct envelopes for this machine or can you use any type, is the weight of paper like is 20lbs
paper, or is it cheap 99 cents paper.
the port where the color ink is spout or ejector port is issue.
call the manufacture customer care center ask for technical services.
go online to the following sites for more help or informations.
www.ask.com/mfg.name/make/model/
/service/manuals/
/operational/manual/
/troubleshooting/guide/
/FAQ/
/customer/service/telephone#/
Oct 06, 2015 | Xante Ilumina 502 GS Digital Color Press...
I have a xante 502 it has streaking on the top side of printing I printed each color and streaking is on each color with black the worst what part do I replace?
if you are familiar with ilumina menu search for the ID Test Pattern. Print test using 11 x 17 page.
On the copy you will see which of the drums need to replace, if the copy has vertical or horizontal lines on it the drum which ever color shows it has to be replace.
Jun 19, 2014 | Xante Ilumina® 502 Laser Printer
How do i adjust the color to color registration. the yellow on my machine is a bit off set
you have misregistration issue? go to printer's menu in calibration, in adjust registration and press enter. it will check the position of the drums. make it 2-3 times. if the result is the same, remove the drum and clean with some alcohol the drum's contact inside the machine. also clean with a cloth the LED surface, maybe it has some toner on it.
if again you have problem, see if you have any old used yellow drum to check.
May 02, 2014 | Xante Ilumina® 502 Laser Printer
131 fatal error
131 code
LED Head Error
131= Yellow Head
Jan 30, 2014 | Xante Ilumina Digital Color Press Printer
Each printed page with a blue stripe come out from printer (ilumina502)
Is it a small straight line or more? MAke a 50% cyan file in corel and print it. If there are for than 1 line is the drum. If you only see a small straight line it wll probably be the cyan LED head.
You can swap it with black to see if the line changes to black.
Apr 18, 2013 | Xante Ilumina® 502 Laser Printer
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
Please what can I do to work the machine that says fatal error 133; for xante ilumina
If you are in a Windows OS it means that:
133 JOIN or SUBST command can not be used for a drive that already contains readers joints.
So uninstall your printer and install it again using the best driver.
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
jasbo
jasbo
