Question about HP LaserJet 4 plus Printer
Printing pages dark
My 4plus complete with a duplexer and extra 500 sheet cartridge and jetdirect has slowly started to pring my pages darker and darker.
When I look at the cartridge, the blue roller is covered with toner, it isn't getting cleaned off for some reason.
Is there something wearing out and is it worth replacing?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
The cartridge itself needs to be replaced, threre is a blade called the drum cleaning blade which scrapes toner off the Drum(blue roller) it is not cleaning the excess toner.
Posted on Oct 17, 2007
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Can I print on both sides of the page
Here are the instructions for duplex printing.
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
1. Open the printer driver setup window, and check the Duplex Printing check box on the Page Setup tab.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note
sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper or Photo Paper Plus Double Sided is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
You can download a users manual for your MX310 at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Please rate this solution. Thanks.
Sep 27, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
My scanner just started smearing the first page of a duplex to pdf but when I scan just front of document it doesn't smear it
Hi
Your question is not clear.
Sometimes using technical jargon makes it harder for people to understand each other (this applies to both askers and answerers).
I always advise askers to use normal language as much as possible and answerers to do the same and where jargon is unavoidable, to explain as they go along.
Please post again to clarify what you mean by "..a duplex to pdf..", in normal language not in technical jargon.
A PDF is not a real, physical document. It is a digital document on a computer or a webpage created in PDF format.
A Duplex document is a real document, printed on both sides of each sheet of paper.
If you are trying to scan a multiple page Duplex Document using the Sheet Feeder of your scanner, the ink on the reverse side may be getting caught up in, affecting and/or staining one of the rollers in the Sheet Feeder.
The bottom roller in most non-industrial Scanner Sheet Feeders expects to touch only the plain reverse side of a sheet of paper as it is passed through and turned over to rest on the Platten (scanning surface) of the scanner ready to be scanned.
Multifunction printers with built in scanners and sheet feeders and duplex printing capability are designed in a way that makes them more forgiving of dealing with duplex printed paper.
Duplex printing printed in a laser printer is less likely to cause a problem as long as it is allowed to dry thoroughly. Inkjet printing that is allowed to drry thoroughly should also be okay.
If the scanning is being attempted very soon after printing, then the wetness of the printing may be the problem.
Sheet Feeders that handle duplex printed sheets invariably become stained and need periodic cleaning.
If the document is not too long, you may have to scan it manually, page-by-page.
If the document exists as a PDF somewhere on your computer or on the internet, then it is unclear why you would need to scan it. This is why your question is puzzling.
Post a further comment, if this answer does not help you solve the problem.
I hope this helps.
Aug 25, 2011 | Fujitsu fi-5750C Flatbed Scanner
HP 5Si printer, multiple images on one sheet HP 5Si, Windows XP, Networked Jetdirect card, 20MB memory, duplex option. Unit worked fine before. Power outage occurred, seemed to have knocked out the...
If this is a "ghost" image like whats on the top of the page is re-appearing on the middle and/or bottom. The fuser is defective and needs to be replaced. Part # RG5-4447
Jan 03, 2011 | HP LaserJet 5si Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
5. Click OK.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
Cannon MP160 How to Print both sides of the Paper???
Set Duplex Printing (Windows) For details on how to set duplex printing, see below: 1. Select 'Properties' from the Print dialog. Note: Properties may be indicated as Advanced, depending on the application software. 2. Click the Page Setup tab. 3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'. 4. Select 'Duplex Printing'. Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed. 5. Specify Staple Side. 1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. 2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. 3. If necessary, click Specify Margin... and set the Margin width 6. When the setting is completed, click the OK button at the bottom of the window. Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side. If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages. 7. You will be prompted, while printing, to remove the printed page and reload it in the ASF. 8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed. Back to Top
Sep 10, 2007 | Office Equipment & Supplies
HP LaserJet 4 plus Printer Logo
135 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
