Question about Husqvarna Designer I
I have a husqvarna Designer SE. After embroidering for a while the thread gets jammed in the bobbin area and makes a big clumped up mess. What's causing this? All I can do is squeeze my scissors under the embroidery hoop and cut the mess of threads because at that point everything is jammed.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
Most likely the thread is riding up and out of the tension disks. Look for the small, round opening in the pre-tensioner. It is the metal piece to the left of the horizontal spool pin. If the thread is on the horz spool pin, it will travel in the rounded opening. If the thread is fed in higher up, it can ride up higher in the pre-tensioner, causing it to not be pinched by the pretension spring and it may ride up and over the top of the tension disks. If this is a possibility, rotate the horizontal spool pin out toward you. Place a spool cap on it and feed the thread around it on the right side and below so the thread feeds into the pre-tensioner horizontally and I think that your problem will go away.
The only reason for this to happen is that you are loosing the upper tension for some reason so if my suggestion doesn't work continue to look at the upper tension assembly and the takeup lever.
Posted on May 19, 2009
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
Husqvarna Designer 1 noise and thread breaking issue.
I would be willing to bet that there is a piece of thread wound around one of those pieces below the bobbin area. Get your magnifying glass out and have it a good long look. When you find thread... use tweezers to pull it out.
Sep 09, 2012 | Husqvarna Sewing Machines
Viking Designer SE-Limited Edition 43 hours of sewing. bobbin thread comes up around edges of desing
try changing the needle
check for burrs in the needle plate area & bobbin area
check also the top thread tension
Mar 12, 2012 | Husqvarna Sewing Machines
My Viking Designer SE Bobbin does not stop winding
I have a Designer Topaz, very similar to yours. There is a small eccentric-shaped piece that rides the thread as the bobbin is filling. On my machine, it can be turned via the little star shaped "torx" depression. This determines the point at which the drive disengages the winding process. In the alternative, when the bobbin is as full as you want it, just push the rider away from the bobbin; the same effect is achieved.
Feb 19, 2010 | Husqvarna Sewing Machines
Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
May 21, 2009 | Husqvarna Designer I
PR600 does not pick up bobbin.
needle/hook timing is off. Best to take it to authorized Husqvarna Viking dealer for service or have them send it to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of authorized dealers is available on the Husqvarna Viking website - http://www.husqvarnaviking.com/us
good luck.
Mar 12, 2009 | Husqvarna Designer I
Husqvarna Viking #1plus bobbin problem
I have changed stabalizers and the type of bobbin thread i am using (invisible poly) and it seemd to have solved the problem. Note: wind invisible thread very slowly and carefully it is like fishing line
Dec 15, 2008 | Husqvarna Designer I
Satin Stitch Problems - Designer SE (similar to the Designer 1)
It sounds like to me you might have some thread stuck in the tension assembly. Possibly some thread "snubs". Also there is an internal service program on this machine that could also solve that problem. That is why you need to take it to a qualified Husqvarna service center to be fixed by a qualified technician.
Aug 09, 2007 | Husqvarna Designer I
Sewing Machines Logo
364 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
