Question about Philips Magnavox 51MP392H Rear Projection Television
Te brand is unknown. Sold by Sears as the LXI Series.I bought this rear projection TV and I was told it needs cooling fluid which I can get for around $20. The guy said the fluid is dirty,causing the
I bought this rear projection TV and I was told it needs cooling fluid which I can get for around $20. The guy said the fluid is dirty,causing the bad picture. The picture fills the screen, but just seems kind of faded, or filtered looking. Does it sound like it just needs fluid? an can I find it for around $20?
  • jellwood61 May 16, 2009
    The link for step by step instructions was an advertisement for HP Printer ink, not changing TV coolant.I don't know if the step by step instructions are the same for my tv, since it's a sears and the LXI brand doesn't match up with anything. A few tips would be nice if O could get them.
  • Philips Master
  • 8,617 Answers
Yes you can find the coolant for around 20.00 for each tube. Or you can get the coolant kit which contains all 3 tubrs coolant and the step by step instructions with pictures on CD at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Posted on May 16, 2009
  • Sonny Berry
    Sonny Berry May 16, 2009
    no the link in blue servicmanuals is the coolant kir for phillips magnavox which is who makes LXI for sears
How to fix my hitachi 65 tv
If you are saying that the picture is getting darker and you have already tried to adjust the picture through the menu feature on your TV then it is more than likely the cooling fluid around the CRT tubes. Over time the fluid in these tubes gets cloudy and causes your TVs picture to become dull and distorts the color. You can google tv repair kits .com and I believe they will have a kit for your model.
Feb 21, 2012 | Hitachi 57F500 57" Rear Projection...
My panasonic projection tv is showing green spots what could be causing this problem.
If you have colored ~1" spot(s) it is most probably associated with EPROM (memory chip) defect. In that case the TV internal computer should be reprogrammed by a certified technician. They fixed mine that I bought in 2006 (4 years) ago FOR FREE.
I called Panasonic using the phone number in the manual (1-888-843-9788), selected Service, told that I got the problem which is most probably "a manufacturer's defect" that should be fixed for free - they redirected me to the next step, then to the next one and in about 20 minutes they arranged me a home-visit by a support person (the guy had to drive 2 hours to get here!).
The service guy came in two days, unscrewed the back panel, connected some kind of a box to one of the boards, turned TV onto some channel and let the box do its job for about 5 minutes - then all of a sudden the spots disappeared and the picture is OK now.
Apr 16, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Have green hallo its not real bad yet but when
The thought is that some of the Glycol 'cooling fluid' has leaked out and this is what is causing your green halo!
I would have a qualified TV Tech look at it.
A/V Media Guy
Nov 25, 2009 | Philips Magnavox 9P6034C 60" Rear...
The screen seems dark and blurry
take off the front panel carefully, usually 2 screws around the controls. Next, stick your head in and look at the red green and blue tubes. see if they are dirty? if, not look further into the tube using aflaslight and see if there is a white pasty looking substance inside. IF so, you need to clean as you have bacteria growing in the cooling fluid. A big job and you need the gaskets, can order from Mitsubishi tech support..good luck be careful.
Mar 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Just bought the Philips 9P6034C 60 in. rear projection, used. The picture is a bit hazy. The buyer told us that we just need to "have the guns put to it". Is there a special tuning device that the tv...
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 07, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
JUMPING VERTICAL WHITE LINES
UNPLUGGED TV FOR OVER NIGHT(WAS TOLD 4 HRS) STILL HAD PROBLEM. TOOK ALL CABLES OUT CABLE BOX,DVD,2 VCRS,AMP,SATELLITE, AND FM AMPLIFIER. OPENED BACK VACUUMED ALL BOARDS WITH SOFT BRUSH ,CLEANED LENSES ,MIRROW,FIRST TIME IN 10 YRS. TV LOOKS VERY SHARP!!!!!!!!!!!!!!!!! I THINK IT MAY HAVE BEEN THE FM BOSTER AMP TRANSFORMER GOING BAD CREATING INTERFEARANCE. JUST A GUSS.. COULD NOT HAVE BEEN THE DIRTY LENSES I DONT THINK THAT WOULD HAVE CAUSED INCONSIST CONSENT JUMPING LINES.ENERY THING RECONECTED (NO FM BOSTER AMP) TV LOOKS GREAT. THANKS FOR YOU GUYS GIVING ME THE CONVDENCE TO GET IN THAT PROGECT. KEEPING FINGERS CROSED.......THANKS TV IS A SONY KP-61XBR300 NOT A KP-57WS500 57 IN.
Nov 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Projection Tv picture
have you checked the cooling fluid in the crts.probably dirty
Jan 20, 2008 | Philips Magnavox 51MP392H Rear Projection...
Maintanence question obout my Sony rear projection.
i,m not a tech but i,ve been told by a techinican that those tubes do have fluid and it,s not an easy fix to change the fluid i was told the tube has to be removed and a tech told me it would run around 200.00 by the time the tech removes it puts the fluid back in and reinstalls it and after it,s reinstalled the convergance has to be reset that,s what realigns the colors back to their correct position and i,ve heard this isn,t an easy job so i,d probably get a techinican to fix it but that,s up to you someone might have an easier opinion but the tech i talked to is one of the best thanks and maybe you can help me i have a blue tube on my big screen tv that wont light upcould you give me some insite as to what you know about a projection light that you said that may need changed think that may be my problem your welcomed to call me about this at 270-566-4327 anytime soon as possible thanks
Nov 26, 2006 | Sony KP-51HW40 51" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
495 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
