Question about Westinghouse Microwave Ovens
Help my microwave won?t stop beeping it?s mounted above my electric stove and it is also the exhaust fan. I use to think it only beeped after I had just finished or during boiling liquid, but lately it even beeps when the stove has not been used all day, it starts beeping at different time of the day during the beeping no touch pad buttons work opening the door will not stop it as well. It can go all night with out beeping and then early morning it will go wild, it may be quit must of the night and then for no reason go crazy. I have no problems with it except when its beeping then nothing works except the beeper
jerryg50
  • 1689 Answers
SOURCE: Random beeping and panel buttons not working
There may be a failure of some type in the system processor area.
Maybe some of the steam from the bioling water and oil and water from the cooking got inside on to the circuit board, and caused some damage.
It is also possible that the heat from the stove did some damage.
It is also possible that there was simply a failure in the system processor area.
Jerry G.
Posted on May 21, 2008
SOURCE: i have an over the stove kitchenaid microwave w
The issue is probably your exhaust fan on your microwave comes on automatically when it detects a certain temperature. Mine does this as well but will turn off automatically after temperature goes down.
Posted on Mar 04, 2009
  • 36 Answers
SOURCE: my Panasonic microwave oven has started
Hi the touch mabrane panel will be faulty and need to be replaced. Best place to obtain one of these or a service engineer is from the manufacturer. www.panasonic.com
Hope this helps
Posted on Jan 07, 2010
arikrom
  • 528 Answers
SOURCE: Microwave beeps for no reason. Panasonic NN-8501V
The touch pad need to be replace, it is not so cheap but if you want to fix it you can order the panel and do it yourself just make sure the unit is off and the capacitor is grounded.
good luck
Posted on Jan 20, 2010
caroldon
  • 17130 Answers
SOURCE: Fisher Paykel Soft Touch stove
Hi Laurie,
It seems that there is some clogging in the circuits that build up when the SET COOLS DOWN. So when the fault occurs please use a hair dryer to warm the circuit areas, the connection cords and the door switch -- check the inputs to the main board. Somewhere there is a short building up to give a malfunctioning.
Since the board was changed with the same result we need to check all other sections for the problems. The touch panel must be clean, is you suspect there were insects infested within then you need to warm and wash the sections clean so that there no residuals from them.
The heating will indicate the area of problem as when the heat is build up the beep must stop. So SIMULATE this process to come to the exact point of fault.
I personally feel every connectors and voltage points must be cleaned. If dirt is seen on PCB , use a soldering iron to touch up.
Posted on Jul 05, 2011
My frigidaire microwave fan turned on by it self. Won't turn off. Blowing air above Microwave
Try unplugging it for a few seconds or turning off the circut breaker to it. This usually resets the unit.
Jan 03, 2015 | Microwave Ovens
My fan for the stove reduces power once the microwave is turned on
you must understand that any manufacturer has the proper design engineering from to save electricity, etc. And they using the new concept of reingeenering.
If the microwaves do not HEAT and working, do not worry.
Mar 06, 2013 | Microwave Ovens
Ge microwave fan vent won't stop
Either a mechanical or electrical issue at the vent.
Dec 23, 2012 | Microwave Ovens
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
How to install a electric line for over stove micowave
This is usually best left to a licensed electrician, however in some homes there is already electrical wiring over the stove for an exhaust fan. You might be able to tap into the exhaust fan wiring and install an outlet that you can plug the microwave into, or if there is an electrical outlet near the stove area you might can tap into it just be sure that you are not overloading the outlet. For example if there is a refrigerator or other major appliance using power from this outlet it might not carry enough current to operate the refrigerator and the microwave at the same time and will cause the circuit breaker to open or fuses to blow.
Sep 09, 2009 | Kenmore Microwave Ovens
LMVM1935SB - Over the Range LG - fan keeps coming on, beeping
The fan will come on if you are cooking below and the area gets hot.... is this when it happens? Sometimes random beep could be a power blip... not long enough for a reset of all things electrical
Apr 19, 2009 | LG LMVM1935 Convection/Microwave Oven
Fan stopped running while heating something up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uyiu4
Mar 17, 2009 | Amana ACO1860 Microwave Oven
Blower motor on above stove microwave not running
The dual fan in the back is the vent / exhaust / hood fa. It will run when you turn it on, or if the stove top gets too hot.
The other fan is the magnetron cooling fan, and it will only run when you are cooking. If it is not running, your magnetron can be destroyed.
You can download GE owner's manuals and installation instructions here. That may help you a lot.
Please reply back with more details if this is not yet a FixYa...
Aug 17, 2008 | Microwave Ovens
Danby Designer microwave (with exhaust fan mounted above stove) stopped working suddenly. Lights are on and microwave sounds audible but no heating of food kept inside.
With these symptoms I would suspect a bad magnetron or a loose connection at the FA terminal of the magnetron.
I would suggest you contact Danby customer service o locate their nearest authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 08, 2008 | Danby Microwave Ovens
Microwave Ovens Logo
154 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
