Washer leaks Kenmore Elite Model # 11022952100 washer is leaking in the front(bought it used from friend). Not sure if it's from the bleach dispenser or the actual machine.Can not find the manual for. Any advice would greatly be appreciated. Thank You Jeff
  • jrlu1205 May 17, 2009
    Hi Mobilian;
    Did as you described and the pics were great.I think I found the problem, a crack in the tub. How do you take this thing apart? My wife downloaded the manual, but it doesn't explain how to break it down. Any advice?
    Thanks Jeff
  • Washing Mach... Master
  • 8,220 Answers
Well Jeff to inspect where the leak is coming from you must remove the cabinet. Flip up the controls unplug the lid switch and pop the S-clips holding the cabinet to the back.Then you can tip the cabinet foward and lift it out the way. Click on this LINK for pictures.washer leaks - b3f4f26.jpg
Posted on May 16, 2009
  • Dan Webster
    Dan Webster May 18, 2009
    Why not just mend the tub? Hint: Bondo
Water leaks out of the soap dispenser of my kenmore elite front loader and all the soap or bleach us not out
The 1st thing to try is to take out the dispenser ,there is a little piece that you will push down and then pull the entire assembly out, rinse it out with hot water ,most likely there is a build up in the dispenser,there after use only powder detergent, and no more then 1 tbs ,and any other stuff IE bleach ,fabric softener,use 1/2 the amount and dilute it with water.
Jul 20, 2014 | Kenmore Elite 45986 Front Load Washer
Water leaking (a lot) from underneath washer
WATER IS NOT GOING INTO THE TUB, INSTEAD GOING OUT. GET A PAINT SCRAPER N PRY THE LID OPEN TO MAKE SURE THE TUB IS IN PLACE WHEN YOU MOVED IT. THERE'S TWO CLIPS BETWEEN THE LID PANEL AND THE MACHINE. PUSH IN HARD AND IT RELEASE THE LID PANEL. FROM THERE YOU WILL SEE THE TUB AND ALL THE WATER DISPENSING UNITS. IT COULD ALSO BE A RIP IN ONE OF THE HOSE WHEN YOU MOVED THE MACHINE. GOOD LUCK
BOYNISMO@YAHOO.COM OR 714-334-1998
Mar 10, 2010 | Kenmore Elite 45986 Front Load Washer
Bleach leaking out bottom of washer.
Not sure what model yu have since there is none posted but sounds like the hose from the bleach reservoir has come loose.
Eric
Sep 15, 2009 | Kenmore Washing Machines
Kenmore Elite HE3t Front Load Washer leak from dispenser
I was just about to call the service teck when I decided I shouldn't be this stupid and try and fix it myself.
I took the tray out and looked in with a flashlight.
Saw nothing.
Cleaned the tray and then checked the drainage hole inside the opening where the tray normally feeds the machine the soap.
I found a inside of the liquid XXXKing laundry cap partially blocking the drain.
Took it out and works fine.
Sep 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Dec 10, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he3
ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Top Load Kenmore Elite Bleach Dispenser Leaking
I have this same problem today and did not need to take off the top panel or remove the front panel/housing. The bleach and frabric softener dispenser snaps right out and you can check the tubing and clamp from there. You will need to remove the top panel if you need to replace the tubing. In my case, there is a crack in the dispenser itself which has ruined several loads of laundry over the past year...now I realize it wasn't the clamp and hose, but the dispenser itself. Check them all while you are at it.
Nov 18, 2007 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
