I'm trying to fix a friend's guitar. The white and black wires of her 1/4" female imput have come loose and I'm not sure on this one where they go.
Well if the actual cord has a removable cap on it unscrew the cap and look under it for the same colored wires.. match her pin socket with the cord connector..unless its a molded wire end....you can do this also..the black may go to the center pin.. the white may go to the ground ...these may need soldered on..
SOURCE: 1992 Isuzu Rodeo Radio Wiring Diagram needed.
http://www.the12volt.com/installbay/vehicles.asp try this site out and see if it will help you.
SOURCE: 1994 toyota 22re 4x4 pickup fuel injector wiring diagram
the color of the plastic plug does not matter... You will have two injector plugs with white/red and yellow wires - those two go to cyl#'s 1 and 3.
the other two plugs will have white and blur wires.. those two plugs go to injectors # 2 and 4.
SOURCE: o2 sensor wiring diagram
A new 02 sensor will come with new wires and connector. If not get back with me I think there is a repair kit for that problem.
SOURCE: wiring diagram for 1998 dodge ram 2500 pickup,
I have the wiring diagrams you need. Send me your email address and I will send them to you.
[email protected]
HU harness color code pretty much universal.
red=ignition
yellow=battery +
black=ground
blue/white=remote turn on
blue=power antenna
pink/black=audio interupt in (not sure if you have one)
speaker wires
gray=right front
violet=right rear
green=left rear
white=right rear
speaker wire with black stripes is negative.
