Question about HP Compaq FS 7550 17" CRT Monitor
Screen color changes, white becomes yellow.
I have a compaq 7550 17" monitor that when you first turn it on is okay, after running awhile the white turns yellow.  I tried shaking the monitor and hitting the sides to see if there is a intermittent connection, but it doesn't clear up when you hit or shake the monitor.  After awhile it clears up until it appears again, this could be hours, days whenever.  Any suggestions?
Steve P
  • hotsexything May 19, 2008
    I have a Packard Bell monitor that when you first turn it on is okay, after running awhile the white turns yellow. I tried shaking the monitor and hitting the sides to see if there is a intermittent connection, but it doesn't clear up when you hit or shake the monitor. After awhile it clears up until it appears again, this could be hours, days whenever.
  • deepak05 Aug 21, 2008
    I have a LG monitor that when I first turn it on is okay, after running awhile the white turns yellow. I tried shaking the monitor and hitting the sides to see if there is a intermittent connection, but it doesn't clear up I hit or shake the monitor. After awhile it clears up until it appears again, this could be hours, days whenever
I think you need to clean your monitor inside of it, dust can conduct heat making the screen material active and creating the yellowish tint to the screen.
I don't think it's a connection problem, becuse it if was you would not see nothing on the screen at all but only one connection error message or like 3 colors.
so you have to open it and clean it I usally use a hair dryer to clean inside stuff or a paint brush.
try cleaning it, but if you have special screws that you have to take out from the monitor you then have to buy special tools for those screws.
I had the same problem right now with my monitor, it's 7 years old, and decided to get a dell flat screen 22 inch.
but that's what I think is your problem, it's either dusty or oxidized meaning different oils are layered inside on the circuit boards. which are like insulators
Posted on Nov 24, 2007
Try moving the cable that goes into your graphics card i had a connection problem with mine, i either moved my tower or the cable to correct the problem
Posted on Nov 04, 2007
Why do i have a green screen after i turn the screen adjustment screw?
since every display color monitors are only work with 3 primary color which are red, blue and yellow. You could also search it that by mixing these colors, you could get any color your want. Thats how color monitors work. Now in case of green color, it creates by mixing blue and yellow. When you are turning the screen adjustment screw, the red color plug will become lose, makes it appear green.
I hope your got the reason.
Jul 10, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Yellow screen hp dv6000
The screen is faulty or the screen cable has become dislodged. Best take it to a repair shop.
Oct 12, 2017 | HP Computers & Internet
I installed an LCW1943TB on my Compaq Presario. When it turns on the background is yellow for my active screens. The desktop also has a yellow tint to it. What needs to me changed to make it white?
right click your desktop back round go2 properties, go2 desktop change your back round to any color or image you like, and go2 themes and select the color tone for windows its really simple.
Feb 23, 2010 | Computers & Internet
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    Screen got yellowish color
    Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing.
    Open the monitor and ring coaxial wire in blue insulation.
    Sep 11, 2009 | AOC CT720G 17" CRT Monitor
    I have a Compaq flatscreen LCD TFT5000 I picked it up used when i pluged it in the colors are all messed up whit has a red hue red is verry bright blue is verry bright and green shows up as Black the...
    NO PC stated, 1984 to 2017, 10,000 models, stated.
    NO OS stated, XP what? must we guess the OS?
    no posted photos, of ugly screens presented by you.
    why do that? leave out the #3 most important fact.s
    michean, = machine, say "PC runs great, "
    no PC stated, no OS stated but it runs great but colors not.
    Compaq monitor TFT-5000 ccfl
    very very old monitor. 4:3 square screen old.
    15 inches sized (tiny)
    18 years old in fact, in dog years that be 126 years old,(lol)
    in all cases of all PCs made ever,
    there can be many causes, no need to guess or for me to list them ALL.
    but here is the MACRO view (from afar)
    Did it fail plugged in to ANOTHER GOOD PC
    no, didnt fail, then,...
    1: The PC graphic chip is overheated. ever clean unstated
    2: PC has CPU oveheating
    3: PC has power supply problems, causing chip to malf.
    4: PC video card bad, or if laptop GPU chip problems.
    5: PC has corrupted or wrong or virus infected Video drivers.
    end.
    anyone else with same problem would do tests or through it away, if bad, its has $0 zero dollar street value like this.
    ever consider upgrading, to something 2010 or newer. ?
    a REAL LED LCD screen. (11 years newer?????)
    your screen has CCFL lamps that turn yellow old, and then go dead. yellow make white look yellow.
    see?
    Oct 16, 2017 | Compaq Computers & Internet
    Emachine monitor lose color.
    HI Bernard,
    This sounds to me like the video lead is loose. Could you please try the video lead each end and tighten the locking screws if possible.
    Regards
    Nick
    Oct 29, 2008 | E-Machines eMachines Monitor E15T4
    LG 700B color problem
    there isent realy anything you can do about this if im understanding this right i beleave the color tube might be toast.
    Sep 13, 2008 | LG Studioworks 700B (White) 17 in.CRT...
    Monitor color changed
    there may 2 problems
    1 ) Problem with the Data Cable connector the Pins might be damaged try to arrange them if disturbed / bend . if Broken change the connector.
    2) Open the monitor see the soldering carefully you can locate out the dry solders easily by seeing the flux colour around it . just put the solder over there..by soldering gun to all places where u can see the dry solder.
    Sep 05, 2008 | Gateway FPD2275W LCD Monitor
    Color problem
    IT is 18 years OLD so has CCFL back lamps that all turn yellow.
    is that it? if the OSD is yellow the (white looks yellow) that means the CCFL black lamp tubes are Shot.
    i cant see what you see, no photos posted.
    ok the monitor has and OSD, on screen display
    i see you found that. but then fail to say what you saw there.
    "you could see the background on the text as white. "
    what does that mean,?
    no matter what that is a bad Monitor.
    the OSD works with no computer at all, so if the OSD fails
    OSD brain, inside, then the monitor is bad.
    all monitors worked previously so is not key to why its failing now.
    only the tests now, matter. today/
    my post above is for any monitor that fails the OSD tests
    no PC turned off. or connected to any PC that works
    the PC resolution must never exceed
    1024 × 768 at 75 Hz Refresh Rate
    on this old old dog. or the screen goes back with error
    OUT OF RANGE.
    Aug 27, 2017 | Compaq TFT5010 (Opal) 15.1" LCD Monitor
    HP Compaq FS 7550 17" CRT Monitor Logo
    1,283 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
