Question about Pioneer Avic-940bt Car Navigation Cd/dvd Player Pandora,bluetooth, Ipod Control
Low output with high volume
Distorted sound at a volume of 25 or greater. worked really well before. not sure when i lost the power. it is in a suburban with bose system. bypassed the park brake sensor and fixed the overheating issues. Now when i turn it up it just starts to distort. I put the old unit in and it sounds great, so its something with the deck or settings.
    Master:
  • 367 Answers
Sounds like distortion is being caused by trying to amplify a low volume level from the input device. try putting the ipod volume at a medium level and try again to see if the distortion goes away/reduced
Posted on Dec 23, 2013
3 Suggested Answers
SOURCE:
  • 135 Answers
SOURCE: Volume control of system output is not stable with
Sounds like a faulty / worn fader. If it does it on all channels then look at the master fader 1st.
A good source of parts is available here :-
http://stores.ebay.co.uk/methleykev
Posted on Jul 06, 2010
  • 135 Answers
SOURCE: I have a DJM 600 mixer and the master volume when
It sound like the master fader is faulty. Look here :-
I have lost my sound from TV through the Bose Lifestyle 48 recently. All other sound sources work fine- DVD/CD, FM/AM.
Hello Sunny,
No TV model... came through with your
Bose LifeStyle home theater question...
I'm just going to mention that I have seen a couple of available configurations... depending on your signal source... BROADCAST, CABLE, SATELITE... (etc.)...
If it is Just your intention to source from the TV...
THERE (at the TV)...
It might be as simple as going into "menu" ... then move down to your "AUDIO" PROFILE.. and make sure your external speaker OPTION is showing "ON" (or "equipped")...
on your TV and making sure your PRIMARY volumes sources & destinations (Bose) volumes at acceptable levels... so as to not FRIGHTEN your neighborhood when the sound does come through)
No success ... comment me back with your TV signal source...
HMDI or optical outputs... (and does your AUDIO Work in STAND-ALONE on the TV... Now??)
If all else is working on the BOSE... I don't think we need to continue there...
Comment me back if you need... I'll be around!
Post comments... addendum
(I did say Menu... (twice))...
RESET , General:
**WARNING:
This operation will clear all of your customized settings.
V... depicts the volume down button on your remote
(immediately above the "menu" button).
With the set turned off...Stand in front of TV.
At the right side on the TV set... locate the power
button on the right side...
WHILE holding down the V (on the remote)
Turn on the TV POWER button on the TV.
(The TV will turn itself off, then back on again.)
Then ... V (symbol) Release the button.
**WARNING:
This operation will clear all of your customized settings...
I'll still be here... comment me back... if you need.
Hope it helps
ELSE ...
We need to move on to your PCBs
Jul 21, 2016 | Bose Lifestyle 48 System
I lost my Bose remote for the sound system, how do I turn on the system?
PDF]TV SOUND SYSTEM - Bose
worldwide.bose.com/axa/assets/.../owg_en_solo.pdf
Bose CorporationTo reduce the risk of fire or electrical shock, do not expose the product to rain or ... be determined by turning the equipment off and on, you are encouraged to try.
Nov 28, 2015 | Bose Lifestyle 25 Series Ii 6 Cd 5.1...
My 07 avalanche has bose s s intermittent sound on left channel
Sound troubleshooting - Bose
worldwide.bose.com/.../en...tv...sound/page.html?...
Bose CorporationSound troubleshooting. No sound from speaker. Make sure the sound system is turned on and the power indicator is on (solid green). Increase the volume.
Aug 08, 2015 | Cars & Trucks
My panasonic dvd stereo system sa-pm91d when the volume is turned above 25, it plays distorted sound, it sounds like I have incorrectly tuned a radio channel even when using the auxiliary input
Hi Gusma,
If you have Distorted sound.
    These may be the causes of the problem:
  • Make sure the speakers wires are properly connected.Check the color codes, be sure they are rightfully followed.
  • - Shorting (bare wires touching) of positive and negative speaker wires.
  • - Using speakers with an impedance lower than that rated for this unit.
  • - Straining of the speakers through excessive volume or power.
  • - Using the unit in a hot environment without proper ventilation.
I am also including a link to the User Manual. Read it thoroughly.
Best of Luck,
JP
Panasonic SC PM91D Operating Instructions Manual
Jun 26, 2015 | Panasonic Audio Players & Recorders
Hello, i have a dell Windows vista and my companion bose 5 wont work.. and ive tried it in another computer and it still wont work. what can be the problem?
Is there any system to which you can connect your BOSE *and* have it work?
If not, then check that the BOSE is getting electrical power into it.
Jul 19, 2011 | Bose Companion 5 Multimedia Speaker System...
2005 Chevy Silverado Bose stereo operators manual, how do I set the EQ presets?
My left front speaker sounds distorted at low volume but sounds ok when I turn up the volume.2005 Chevy silverado bose stereo and speakers
Apr 30, 2010 | OEM Systems Car Audio & Video
Can't get video to work so bose works with tv sound
We fixed it. We had everything hooked up right, but - stupid us - we didn't turn the sound off on the TV. Once I turned the TV's sound setting to off, I flipped the speaker switch a few times on the Bose remote, then turned up the volume on the Bose and it worked.
Sep 19, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose SA2 distortion
As the distortion is on both channels it must be something to do with something that is common to both!
My guess is an IC. Check to see if it uses an IC for the main amplification. They are big with loads of pins coming out of them. Sometimes marked STK and then a number. If you find one it will have gone! Replace it with the exact part.
May 04, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Bose Lifestyle 35 Accoustimass module rattles at high volume
Well to be hones 85 sounds pretty loud to me, generally the bose acoustimass module shouldnt really be distorting or crackling unless under extremely high sound levels.
It could possibley be that the speaker cone in the bass module has a slight perforation so it would distort at high levels. However other problems could be loose connections inside the unt or outside the unit. If your friend doesnt have it above 85 under normal circumstances I wouldnt worry to much about it but if there is a tear in the cone the problem could get worse.
Nov 27, 2008 | Bose Acoustimass 15 System
Pioneer Avic-940bt Car Navigation Cd/dvd Player Pandora,bluetooth, Ipod Control Logo
97 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
