Question about Motorola Mobility RAZR V3
Razor battery won't stay charged
I want to replace the battery on my motorola razr phone.  How do I remove the battery to see any numbers I might need to tell what battery to order.  Is there a way to tell what model phone this is?
  • 94 Answers
Yes there is there should be a few settings on your phone which will display specific settings showing your model , or if not then just look at your phone box , receipt or if your in town take it to a local shop they could tell you straight away. or take a picture of it and send it to me via email and i could tell you what it is ?
Posted on Oct 17, 2007
Overheating of razor phone
the v3 is known for battery issues. not charging, not holding charge and overheating. my suggesting is get a different model phone. and stay away from razors. they all have battery issues, I know this from multiple customer razor issues. all battery issues.
Jul 22, 2009 | Motorola Mobility RAZR V3
Razr not charging -
New charger is needed - Razors are VERY particular about their type of charge - If it is a bad charger - You will see the battery indicator flashing red - and it will be empty - this is the phone saying pretty much that it cannot use this charger -
I have had ALOT of problems with razors and returned chargers - Try to scoop up an original - or take it to a location and test the charger first -
You can try to remove the battery and then put it back in - then try to charger it but i doubt that will work -
Get a new charger - TEST IT FIRST IN STORE!!!
Good Luck!
Jul 17, 2009 | Motorola Mobility RAZR V3
Motorola razor not charging..after 1 mth of use
i have one just like that. it was because i over charged it. take out your battery when mine did that the battery looked a little bowed out on both sides. the salesman called it an exploded battery
Jul 07, 2009 | Motorola Mobility RAZR V3
How do i remove my motorola razr v3 br50 battery
take off the back plate, push down on the battery, you should feel it give a little. While pushing down, tilt it back. It should come right out.
Jun 24, 2009 | Motorola Mobility RAZR V3
Razor
HI,
Every phone battery has a life cycle. if the battery is more than year old , it most probably requires a replacement. As its not able to retain charge. If its under one year , get the same replaced from the motorola service center . I had the same problem with my razor and they replaced it free of charge as the same was under 1 yr .
Thanks
Proton
Apr 22, 2009 | Motorola Mobility RAZR V3c Cellular Phone
My razor won't stay on!
try a new battery and also take the phone and have the firmware reflash on the phone to correct this problem
Sep 30, 2008 | Motorola Mobility RAZR V3
Razor battrey
Did the phone show it was charging on the display? Was the charger firmly connected to the phone? The batteries will go bad after a period of time of recharge cycles. I have bought replacement batteries for my RAZR on eBay. Remove the battery and do a search on eBay for a NEW battery from a dealer using the battery P/N on the battery. I found a higher capacity battery for mine that lasts even longer on a charge than the original one that came with my RAZR. You can do a search on eBay for "RAZR battery". Look at the mAH rating on your battey, Try finding a replacement with the same or higher rating than your original. The higher the mAH rating, the longer it will last between recharge cycles.
- Jim
Jul 08, 2008 | Motorola Mobility RAZR V3
Razor v3 new battery charge problem
GUEST - replaced the battery if the phone still gets hot then you need to replaced the phone.
Eror08 - change the battery try that first
Jun 05, 2008 | Motorola Mobility RAZR V3
RAZOR V3
HAS IT BEEN WET? IF SO OPEN BATTERY DOOR AND REMOVE BATTERY THEN POUR RUBING ALCOHOL NOTE MUCH THEN VACUME NOW PLACE IT UNDER POWERFUL FAN OVER NITE.TRUST ME IT WORK'S...
Feb 01, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
