Question about Car Video Monitors
Steering Column in a 1993 Mercury Villager LS
I am wanting to know the specifications and also how to put one in, because I have to take one out to replace the old one in my van.
0 characters
1 Points
I have a 2002 Mecury Villager and I am having the same problem by texansrule on Nov 10, 2009. I have replaced the oxygen sensor and knock sensor and now the inspection office said that the computer can't...
take it too the mecury dealer it computer to read it and a code reader just cant get to were your code is in the system . the tech1 or tech 2 computer is what i used at chevy to check the all the sensors and computers in a car or truck it gives alot of data to the tech to make sure things work right.
snap on tools make there version most shops charge a fee to put it on there computer and check it out .. call around ... ask for if they have a computer to read the codes not just obii code reader at some of the local shops near u
Oct 16, 2010 | Car Video Monitors
Video Connection for NECVOX RE-7269
I can try finding a replacement, it will bea sier with part number
Apr 12, 2008 | Car Video Monitors
Rain Rain Go Away?I Need to Drive Today
It has only been a day or so, but it feel like it has been raining here since God was a child. I have a few friends who will be out driving in it, and I was reminded of a driving tip I wanted to share. It's about hydroplaning.
The driver, you know, the one daydreaming, or half asleep, putting on makeup, and is listening to the rain drops on the roof of the car, or engrossed in NPR, will be taken by surprise when the car suddenly picks up speed as it enters into the hydroplane. Yes that's right. It goes faster. And rather fast…um…I mean rather suddenly.
When water collects on roadways during a downpour, and you come barreling down the highway with limited visibility (hopefully your lights are on), in order for the tires of your vehicle to remain in contact with the surface of the road, the tires need to push the water aside in order to plow through. Like parting the red sea. If the threads on the tires are worn, there’s a good possibility the water will stay right where it is. This leaves a thin layer of water between the wheels of your car and the surface of the road. When this occurs, the vehicle will “hydroplane”. Meaning that a flat layer of water is your new road. And that doesn’t leave much traction for the tires. The lack of traction between the tires and the road decreases the amount of drag (or resistance) so the vehicle gains forward momentum.
Here’s how that plays out. You’re bee bopping’ down the road in the rain and hating your boss for making you drive into the office when you could have easily worked from home, and your tires loose contact with the road surface and you and your trusty vehicle go gliding across a sheet of water like an olympic figure skater. If you’re lucky, the vehicle will continue moving in the same direction and with the front of the vehicle leading the way. If you’re not so lucky, the back of your car will be leading the way, then the front, then the back, then the front, then…
If this ever happens to you, NEVER, NEVER, step on the brakes. Why? Because stepping on the brakes will prevent the tires from rolling. If the tires aren’t rolling, but the vehicle is still moving, then you are skidding. And that’s almost like hydroplaning. Except with skidding, you have more friction. With friction, you have more traction. With traction, you have control. With hydroplaning, you have a big hunk of out of control useless mechanical energy parting the waters as it spins along the interstate at high speed. With you in it. Getting dizzy.
What you should do is remove your feet from the gas and the brake pedals. Hold the steering wheel firmly as your vehicle initially picks up speed. Your job at this point is to try and keep the vehicle heading in the same direction as before the hydroplaning began. You do this by turning the wheel ONLY if the car begins to turn first. You want to turn the wheel in the direction the back of the vehicle is moving. Basically, that translates into turning the wheel in the opposite direction of which the car wants to spin. Turn the wheel just enough to compensate for the vehicle wanting to spin/turn.
As the vehicle turns to the left, you turn the wheel to the right. Then as the vehicle changes direction and begins to turn to the right, you turn the wheel to the left. These movements will be large at first, but with each turn they should become smaller and smaller until the vehicle comes to a complete stop, or until the tires regain traction with the road surface.
If the vehicle stops completely before you regain control, you could be facing any direction. If you haven’t collided with any other vehicles, calmly and quickly restart the engine if it stopped, and continue driving. Don’t sit there waiting for someone to come crashing into you. If you need to do so, drive your car to the side of the road to regain your composure but do it quickly.
If the vehicle doesn’t stop, but instead you gain control, then just keep on going as though nothing happened.
Happy Trails,
on Apr 12, 2010 | Car Video Monitors
Time on car radio display
With the ignition key in position 1 or
higher, you can use the button in the
turn signal lever to request information
from the computer. Each time you
press the button briefly toward the
steering column, a new function is
called up in the display.
The displays appear in the following
Time of day, outside temperature, average
fuel consumption, cruising range,
average vehicle speed.
higher, the last active setting is displayed.
press the button you mentioned when the
time of day displays and turn to right to set
ahead left to set back
Nov 18, 2007 | Car Video Monitors
I have an Audiovox Overhead DVD player in my 2006 Ford Explorer which was installed at time of purchase. It doesnt work at all and I just want to replace it with a better one. My question is, are there...
You can possibly use the old base but it will depend on the video screen. the new unit will absolutely need to be connected to the radio. Some web sites to ponder on and and these sites have good prices. Hope this helps leave feedback if so. thanks
Jun 06, 2010 | Car Video Monitors
Need code to 98 clk benz radio
Radio code is specific for each and every car. It is specific like anti theft code.
So you can get it by providing your VIN# and registration details in authorised dealership.Nobody else can provide you. If anybody can provide you that , then there is no meaning of security for your car.
May 19, 2010 | Boss Car Video Monitors
Renault clio
your owner manual should show you look in the index
Dec 05, 2008 | Car Video Monitors
Comes up with disc error
cd cleaners usually cause more damage than good by scratching the eye that reads the cd. my recommendation is to try and find where your local alpine repair place is and bring it there.
Dec 02, 2008 | Car Video Monitors
Vauxhall astra club 1.6 8v 2002
My 55 reg Astra ecotec 1.6 z16xep engine horrible tappit noise and miss fire when started from cold, and when warm makes a clicking noise when running.
Feb 27, 2008 | Car Video Monitors
check your #1 plug and see if you are getting spark my be the distuberter cap or rotor is bad
Dec 23, 2007 | XO Vision GX1211 XOVision 12" Roof Mount...
Car Video Monitors Logo
57 people viewed this question
Top Car Video Monitors Experts
xxxxxx xxx
Custom Exchange
Custom Exchange
Are you a Car Video Monitor Expert? Answer questions, earn points and help others
