Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 dvd player does'nt read any dvd
I have his dvd player since long time and it was working fine but now If i put any dvd then it does'nt read and i check that power supply and otherthings are seems to ok.
I have CH DVD 300 Model, i have purchased this DVD on 2007, yestarday (17/05/2009).
When i put DVD in, i cannot see any screen on TV, perviosly i can seen default screen CYBERHOME, all other things are ok, (powe on ok, eject & incert ok,) dvd is not playing after putting DVD in CYBERHOME.
pL. give solution on my mail Email ID: shankarg@iss-global.com, gudala2000@gmail.com
at the earliest.
With Regards
Gowri Shanker
India
Posted on May 18, 2009
MY CYBERHOME DVD PLAYER IS READING INSERT DISC AT ALL TIMES AND WILL NOT PLAY ANT DISC. HOW TO RESET CYBERHOME 300 DVD PLYER?
I am sure problem on Laser,may be it does not read any disk.So all times it say insert disk.You can better opportunity replace this damage laser.
Aug 10, 2010 | Cyberhome CH-DVD 300 DVD Player
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Cds fine; dvds won't load
Most likely the DVD laser lens is dirty. Unplug the CH-DVD 300 from the wall outlet, wait 5 minutes, then remove the top cover. Next, remove the rectangular metal plate which covers the area where the CD or DVD disc would be when in the player's tray. Underneath the rectangular plate you should see two small lenses. Gently clean these lenses using ear swabs moistened with isopropyl alcohol. Reassemble the CH-DVD 300 in the reverse order that you disassembled it, plug it back into power, and now it should read your DVD discs just fine.
Aug 13, 2009 | Cyberhome CH-DVD 300 DVD Player
The remote does not work on my cyberhome ch-dvd 300 dvd player. The unit itself is fine
Working remotes for cyberhome dvd players can be purchased on the e-bay website. You can also try having some one look at the unit , it may be a simple problem of cold solder joints or loose contacts with battery holder causing your remote failure. If not for a few dollars you can find a working one on e-bay. I hope this helps you with your problem.
Apr 09, 2009 | Cyberhome CH-DVD 300 DVD Player
I cannot get my Cyberhome DVD to work
Hello
I have a cyberhome dvd player CH- DVD 300 had it for a 1 year i but in a orginal dvd movie and it does play it it said no disc I but in dvd cleaner it read for a moment but when i put in the orginal movie it said no disc again is it the sensor or what, what should i do???
Aug 18, 2008 | Cyberhome CH-DVD 300 DVD Player
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
No display only audio
Dear friends,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec
Oct 28, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Lost sound on DVD
I have a CH-DVD 300--not sure how different it is from the 200, but I have the same problem. Putting in an audio CD seems to do the trick, and is less hassle than unplugging (which also works for me).
May 20, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
182 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
