Question about Sun Time NCAA Purdue Boilermakers Competitor Steel Watch
Boiler problem boiler hot water has no problem but central heating goes on and off every 5 to 6 seconds, any advice, please. My bolier is Vaillant turbo max plus 828e. thanks
  • 36 Answers
Check the air flow,venturi in fan and pressure switch
Posted on Jan 24, 2010
Worcester MT10 Timer doesn't start. The clock seems to work fine but when it is time to start the heating system doesn't. Please someone csn help me? Thanks
Go to http://www.worcester-bosch.co.uk/homeowner/boilers/boiler-controls/which-controls-go-with-my-boiler/mt10-mechanical-timer. They have a video and instructions plus a downloadable manual to walk you through the process. If it still doesn't work maybe you should return it a get a new one.
Nov 07, 2012 | Watches
My Jacques Lemans G-190E's second arm move once every 5 seconds, is this normal? Please advice! I just take it out from the gift box. Thanks!
No worries - just replace the battery. As the battery was fitted at the time of watch assembly, it is actually already old. The seconds hand movement by 5sec increments indicates low battery power, so, next time you see that - you will know what to do.
Feb 25, 2011 | Jacques Lemans Watches
Need to sync digital and analog screens?
There are instructions on here and in the tissot website. However in basic layman terms here goes...
Press central button and hold for 5 seconds til 2nd beep heard. press centre of glass to show 24hr CM display. Sync will appear in LCD window.Then press top button (mins hand) until hand at 12 exactly. Then press bottom button( hrs) and again hold til at 12 exactly then press centre button. This hould fix sync.
My problem is that I changed my 4 year old battery today and at first heard a beep, removed battery as fiddley closure of base and redid battery. Now I have nothing at all. Could i have possibly shorted out the watch and what do I do now?
StevieG
Dec 27, 2010 | Tissot T-Touch T33759851
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Hi I have a Tissot T Race watch (model # T011417 A). It is still under gurantee, but I noticed that every 24 hours, there is a delay of 5 seconds in the watch; in other words (1 minute and 10 seconds...
I agree with the repair service, in that it probably is not a big deal, but since it is still under warranty, I would contact Tissot at the following to get their professional advice on their product.
http://www.tissot.ch/?mod_contact
Best wishes.
Aug 12, 2010 | Tissot T Race T90444631 Watch
Second hand on my watch now goes in 5 second intervals
Check the instruction manual if you have one. Tag-Heuer watches move in 5 second intervals to let you know the battery needs replacing. A neat feature. Now you know that you have a real Tag!
Dec 30, 2008 | Tag Heuer Link Automatic Chronometer...
Bench Watch BC0088 set up manual
Hold down the bottom left button for 5 seconds. It goes to set mode.
Apr 26, 2008 | Watches
Tag Heuer 200meter Professional series
This is to let you know that the battery needs to be replaced.make sure that you use a watchmaker that can test and replace any worn case parts so that your watch will retain it's original design water resistance.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Oct 21, 2007 | Tag Heuer Link Automatic Chronometer...
Sun Time NCAA Purdue Boilermakers Competitor Steel Watch Logo
291 people viewed this question
Top Sun Time Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Sun Time Watch Expert? Answer questions, earn points and help others
