Question about Maytag Atlantis MAV8000
High pitched buzz/whine during wash cycle only, spin fine
My Maytag MAV 8260 has started making a high pitched buzzing/whine during the wash cycle. It does not make any noise in spin cycle. Where do you suggest I start?
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
Posted on Nov 16, 2012
My new front load washer makes a high pitch sound when water is going into it
Posted on Oct 07, 2009
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Maytag MAV 8260 AWW Does not work at all. No water flow, no spin (even when filled with water from hose) Does it have an internal fuse? Where is it located? Is the large timer switch the brain of the...
Some model have fuse in top control panel, check lid switch, yes large button is the brains, it sometime can fail but usally only takes out 1 of the cycles.
Nov 02, 2013 | Maytag MAV7600 Top Load Washer
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Kenmore washer doesn't drain
This is likely a pressure switch issue.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Maytag SE1000 Dryer - high pitch buzz, then total non-start
Often, after a power surge that exceeds the parameters of surge suppression devices on the circuit board, the unit will do this. You will more than likely have a failed control board now and will need to replace it.
Dec 03, 2008 | Dryers
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Open Questions:
Washing Machines Logo
1,298 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
