Question about Acer Aspire 5050-3242 Notebook
Wireless connection turns off when power supply is pluged in.
  • Acer Master
  • 4,338 Answers
  • Right-click on "My Computer" and select "Properties"
  • Select "Hardware" and click on "Device Manager"
  • Find your wireless card under "Network adapters" and double-click it.
  • Verify that there aren't any auto power management settings enabled that might be shutting your card down prematurely
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Posted on May 16, 2009
    I have a acer laptop the keeps turning off wirless connection
    There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
    Aug 20, 2012 | Computers & Internet
    I have just got a wireless xbox an i have pluged
    Do you mean you got a wireless adapter?
    This is taken off the support site from xbox. Also try to unplug your router for a min and plug it back in. It is called a power cycle. That is what I had to do.
    To set up your wireless adapter:
    1. In the Xbox Dashboard, go to My Xbox and open System Settings.
    2. Select Network Settings, Configure Network.
    3. On the Basic Settings tab, select your wireless settings.
    4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
    5. If your network has wireless security, enter your WEP or WPA key.
    6. Try to connect to Xbox LIVE again.
    Mar 14, 2010 | Microsoft Xbox 360 Arcade
    Netgear software, picks up wireless network then loses connection moments later
    Netgear generally functions well. You may simply need to adjust the location of the router. Check the signal strength when you do have a signal. You may be losing a signal intermittently because the signal is weak. If your signal is "good" or better and the signal is lost without apparent reason, there could be a malfunction with the router itself. Check the router when the signal is lost and ensure the power light is on and the connection light is on.
    If your signal is weak and you lose it intermittently, adjust the location of the router
    If your signal is strong and you lose it intermittently, you may be experiencing a connection problem at the source or the power may be cutting out at the modem. The more likely answer is the source signal interruption. It is rare for a power supply to go bad in those.
    Check the source connection INTO the router.
    You can also reset the router. You'll want to unplug everything. Unplug the power supply from the wall AND from the modem and leave it unplugged for at least 2 minutes. There may also be a very small recessed reset button (the kind that you need to use the end of a paperclip to press). Press and hold that for 10-30 seconds to reset while it's still plugged in.
    When you plug everything back in, plug the power in first (to the wall and modem), then connect the source cable. Wait until you have a signal confirmation light, then try to connect with your computer.
    Last but not least, the connection problem could be with your computer. Try pluging directly into the source if possible and see how that works. Then try just moving close to the wireless modem and see how the signal strength is and if you lose the signal the same way. If there is a switch on your computer to turn on the wireless feature, make sure it's all the way on. Sometimes these are kind of stuck between 'on' and 'off' and that can cause problems.
    I hope one of these suggestions helps you!
    Jan 12, 2010 | NetGear RangeMax WPN824 Wireless Router...
    Xbox wont turn on its pluged in and getting power to the unite but wont turn on
    What color is lit on the power unit? Is it red, yellow, or green? Are you using a wireless controller to turn it on or the actual button on the XBOX? If you're using the wireless, make sure it's plugged in to the unit and controller. If not, replace batteries in controller and see if that works. If still nothing make sure you have a good connection between the power unit and the XBOX.
    Dec 06, 2009 | Microsoft Xbox 360 Console
    When power supply pluged in the wolfer makes loud noise
    Try turning the volume down on your computer or on the woofer itself.
    Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
    I pluged in the power but it won't turn on
    Mismatched power supply, bad AC outlet, and/or dead router.
    If under warranty, get a return authorization.
    Jul 09, 2009 | Dell TrueMobile 2300 Wireless Broadband...
    Laptop does not turn on.
    it is the problem of you power cable pluged into the laptop from adapter which does not supply the steady current to your laptop the it causes the disconnectivty
    Jun 01, 2009 | Acer Aspire 5500 5570-2609 Laptop
    Cant connect to the internet
    red light means moden is out of sync with the isp. Power cycle. by unpluging the power from the back of yoru modem, unplug Your router and also turn off your computer. Turn on your modem frist wait until all lights are green>If they dont turn green. CHeck your cables. make sure telephone line is plugged into it or cable line. . There should be a cable pluged in from your modem to your wan port. Then from your router to your computer. Is this a wired or wireless connection. If its a wireless connection i need to know what what os your using. so i can help you set it up.
    Feb 05, 2008 | Arris WR850G Router (DHWR850G)
    Acer Aspire 5050-3242 Notebook Logo
    95 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
