Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Cant get spark on my husqvarna 380cd
Cant get spark on my stihl 20av chainsaw. i cleaned flywheel and pickup then reset it, still nothing. what should i try
  • fastcash_80 Jun 01, 2009
    it had a break in the sparkplug lead where it runs through the casing. out of sight, out of mind.
  • 25 Answers
Did you try a new spark plug
Posted on May 16, 2009
Can't get a spark on Stihl 020 chainsaw. Tried another coil and switch module but still no spark
It is possible your flywheel has lost it's magnet strength, if you noticed it turn a blue. Can take off flywheel and replace with a good one. Or you can play with the gap on the magneto/coil, and insert a piece of paper between the coil and the flywheel magnets, to set for air gap.
Sep 09, 2013 | Stihl Handle Chainsaw 020 Avp
Husqvarna 36 cc chainsaw wont start replaced spark plug cleaned carb
Are you getting a spark..? - NO? check wiring loom from ignition module, check timing gap between flywheel and ignition module, check on/off switch.
Does it have compression.? - NO? then check piston/rings and cylinder
Is fuel getting to the cylinder.? - NO? Carb problem of fuel line issue
Dec 06, 2012 | Husqvarna Garden
Stihl 066 does not start. Replaced ignition module. Weak or no spark.
Are the poles on your flywheel blue? Are you using an open-air inline spark tester, or holding the plug against the cylinder and turning it over?
Jul 14, 2012 | Stihl Chainsaw 051 075 076 Drum Chain Saw...
Ihave a ms 250 stihl chainsaw. Icannot get it to get spark . Ichanged the spark plug several times ive taken the coilout and cleaned it cleaned fly wheel .I ran for little now it dont. Ithas been siting...
Remove the flywheel and make sure the flywheel key is not sheared. If the flywheel key is intact then you have a bad coil. Remember to set the coil to flywheel gap to
.010 or just use a business card to set the gap.
Feb 20, 2018 | Garden
Not starting No spark
Not common, but it can happen to any saw over time. Try a new plug first and recheck--make sure the ignition switch is set to run. If still nothing, remove the case on the flywheel side to expose the flywheel and ignition module. Check the module pole gap to the flywheel magnets with a thin business card. If ok, remove the ignition switch wire from the module and recheck spark. If now works, check the wire and switch. If still nothing, time for a new module. Hope this helps!
Apr 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Weak spark hard start stihl 021
Check the pole gap on the ignition module to the flywheel magnets. Use a thin business card for a gauge. If it has the correct gap and you have tried a new spark plug, then the module itself is likely failing. Hope this helps!
Apr 14, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
No spark in stihl 025 chainsaw. I replaced the
check the ground wire on the on and off switch, it could be a bad ground
Mar 15, 2010 | Standard Oregon Chainsaw Chain For Stihl...
No spark and dont know the settings on the coil or
I just checked a dozen or so Stihl saws, 0.008 - 0.010" is the normal coil gap. Card stock is usually 0.085 - 0.095"
If you still have no spark after assembly please reply below and I will happily assist you.
Lou
Jan 27, 2010 | Garden
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
234 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
