Question about Sony KDF-E55A20 55 in. LCD Television
Screen became dim over time and then blank. Red LED lights blinks when on and sound is fine. Is this the bulb, unlike the others that went suddenly?
  • 363 Answers
Re: Screen became dim over time and then blank. Red LED...
There is more than one flourescent tube in your TV, It could be possible that one after the other has failed, these should usually last a few years depending on usage.
If it is not the tubes then there may be a fault in the backlight inverter although this would more likely show up as a sudden failure.
How old is your TV?
Posted on Oct 16, 2007
0 characters
3 Points
How to replace a bulb
Depending on the type of TV the backlight will usually be either LED or CCFL. If the backlight is the only fault then the TV will still have sound and a bright light from a torch shone at an angle onto the screen should show a faint picture. Repair of the backlight is not a simple task and could be a number of different causes. LEDs are unlikely to fail in such a way as to blank the whole screen. CCFL tubes can cause the whole screen to go dark but replacement is very difficult. I would recommend getting a TV repair engineer to fix it.
Mar 14, 2016 | Flat Panel Televisions
When I turn on my 50" Plasma TV the light goes from red to green. The Green LED flashes 14 times then solid. There is a white raster but no picture or sound.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 16, 2015 | Zenith Z50P3 50 in. Plasma TV
Pn43d490 clicks blinks red light twice and will not turn on
do you have a dim screen? if you put a torch to the screen at an angle can you see the picture?if so this means the backlight is out, it could be the inverter board or the bulbs themselves though this is you get the 24Vgoing to the backlight from the psu?
Dec 09, 2013 | Samsung PN43D490 3D Plasma TV
KDL-55HX800 Tv turned off after 30 Sec
How many times do this LED blinks at one time switch ON? These are called blinking codes, and are fault indications. From the number of blinks, you can get an idea about the faulty circuit section inside it.If you wish to get more details, surf this link.
May 22, 2013 | Sony KDL-55HX800 55" 1080p 3D Ready LCD TV...
I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Mar 09, 2011 | Sony Flat Panel Televisions
MY SONY TV LCD MODEL KF-50WE620 screen went blank. When I turn on the green light it blinks on 40-46 times every second, then turn to red color to Stand mode and blinks for 160 times, then move to power...
There is no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Tom Miller
Broadcast Eng
Mar 04, 2011 | Flat Panel Televisions
Panasonic Projection HDTV Made 9/2003
Your lamp has most likely blown out. that is what happened to mine and once I replaced the bulb it worked just fine. this is one of the cheaper stores to find a replacement bulb,
Aug 29, 2007 | Panasonic PT-40LC12 40 in. LCD Television
Sony KDF-E55A20 No picture or sound
The little flashing light down on front of your TV will tell you the problem by the color of the light or the blinking intervals, this is the reason you can not turn it off is telling you something. The manual should have a section dedicated to this part, most likely is the bulb, the bulb is easy to access generally hold by one or tow screws you can pull it out to verify the integrity of the bulb. Then again check the LED light before anything then you go from there.
Aug 28, 2007 | Sony KDF-E55A20 55 in. LCD Television
Blinking Red Power Light
It sounds like the horizontal (H stop) and vertical (V stop) has gone bad. Check Cap 515 and 516. IC1509, Q1505 and the jungle IC, IC206. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC.
Jul 06, 2007 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
106 people viewed this question
Top Sony Flat Panel Televisions Experts
Mando Mojica
Mando Mojica
Brian Sullivan
Brian Sullivan
Are you a Sony Flat Panel Television Expert? Answer questions, earn points and help others
