Question about RCA F27450 27" TV
I have an RCA 27' tv that is 3 years old. I turn it on and it stays on for 2 seconds and then turns off. Is this an easy fix? We have tried leaving the unit unplugged for a couple days, and it still doesnot power on.
techman
  • 3130 Answers
SOURCE: tv will not power up
no reset button ,sorry. The problem you describe is pretty common with this model as its a fault in the horizontal drive circuit or in the main power supply and without the proper service manual as well as the prober tools and equipment this set its not gonna get fixed. there are no panels or user changable boards as it is a solid state set. ptscorp.com could repair this board or exchange it with a referbished board but it would still requir some adjustment that a user may not be able to handle. time to call the pro.. Sorry couldnet help ya more.. Good Luck.
Posted on May 24, 2006
snakehead
  • 1074 Answers
SOURCE: RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Posted on Jun 04, 2007
techman
  • 3130 Answers
SOURCE: RCA 27" TV Guide Plus
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
Posted on Oct 16, 2007
  • 1153 Answers
SOURCE: RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Posted on Jan 08, 2008
mjap
  • 107 Answers
SOURCE: RCA F27227EM 27''
maybe an IC is mulfunctioning around the power suply. a four leg IC, sometimes its white or gray, try to change it.
Posted on Jan 19, 2008
I have a 52" RCA
sounds like the power supply capacitors CP150, CP120 and CP114 need replacement. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the caps and the CD with repair instructions.
Aug 05, 2011 | RCA HD52W56 52" Rear Projection HDTV
My RCA truflat tv won't turn on? It is only like
Could be a fuse in the unit or a bad powersupply i would have a estimate done on it before repair gets started as a newer tv would cost less if this was a major issue.
1. check fuse
2. check power supply unit
If you do not know how to do this would recommend you take it to the experts as there is serious high voltage that can be fatal inside, Please do leave postive feedback and ratings for your free answer today.
Oct 24, 2009 | RCA TruFlat 27F520T 27" TV
Tv comes on and off by itself, sometimes it blinks on and off. tv is 3years old. i put all my cords on a power surge . i recently put a dvd on my tv. need help to see if i need to buy another tv?
rca tv alway have that problem. you could try to clean up all control bottom in control panel or change all.if not. best thing you take down all bottom then only use remote control to operation that tv. good luck!
Jun 01, 2009 | RCA TruFlat 27F520T 27" TV
CURSED RCA
its the EPROM chip and it is happening in thier other models as well. If you leave it unplugged for about a couple of weeks it will work for a while but will start again and it will get worse
Sep 26, 2008 | RCA TruFlat 27F520T 27" TV
I have a rca 27 inch tv modle # 27v514t sdTV.when i turn it on 2 or 3 seconds it shuts off
The cable running from the button on the front unplug it as soon as you get the tv to turn on it should stay on.
Jul 28, 2008 | Televison & Video
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
Toshiba television
Is it a Toshiba or RCA? What's the model number?? When it "stays on..." do you get a picture and audio okay??? If you continue turning it back on does the lapse in time continue to get longer????
Bill
Nov 27, 2007 | RCA F27450 27" TV
Green lines at top
well i think your husband is right. it might be three years old, but the sligtest damage can kill it. so what you need to do is start saving up for a new tv. sorry for waht happened. maybe somebody hit the screen?
Sep 01, 2007 | RCA 27R410T 27" TV
Jun 04, 2007 | RCA 27R410T 27" TV
TV wont turn on?
this product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Dec 08, 2006 | RCA 27R410T 27" TV
RCA F27450 27" TV Logo
181 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
