Question about LG RH1999H DVD Recorder/HDD Recorder
Getting 'Record-blocking signals detected'
I try to record a program (from cables) to HDD on my DVR RH1999HS and get the following message: Record-blocking signals are detected. Is there any way to get around? Thanks Mark
5 Suggested Answers
SOURCE: lg lra-850
The program is protected from copying. It is possible a synch restoral box such as the Optex Video Stabilizer could help in series with the video IN (composite video only) Mine is model # VO760, an old one.
Posted on Mar 07, 2008
SOURCE: how to connect DVR 1600 to LCD HD TV or ATT uverse recorder
Use 2 scart leads from av1 and av2 of the dvd via a spliter .
With the out put from spliter pluged into tv.
(DVR 1600 output is 1/2 of a scart socket and the input is
the other 1/2).
ps:- no auto switching on o/p or i/p!
Posted on Jun 09, 2008
SOURCE: LG RH399H
I have the same problem with the same model LG, bought a year ago. It only gives the 'Record-blocking signals detected' message when there's something I really want to record. Over the winter it was Jane Austin's Pride and Prejudice. Today it is the British Open Golf from Turnberry. We are out tomorrow, for the last day of play and can't record!!!!! It seems this player has build in blocking signals even to channels we can normally watch. Any help would be appreciated - before tomorrow, July 19th.
Posted on Jul 18, 2009
SOURCE: Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Posted on Nov 14, 2009
How do I record from DVD to HDD
DVD player AV out to HDD AV in RCA cable red white yellow
HDD input source has to be AV in you may have to set up a timed program chanel to av in av1 or av2
you may not be able to do this due to copyright embedded signals being detected by the HDD
Oct 17, 2016 | Toshiba RDXV60KB DVD HDD VHS Recorder
Cannot record externally from Humax bt you View box onto Toshiba RDXV60KB ( HDD & DVD modes). As I previously could? I am getting message E26 " Cannot record from this program". But the Tos
This error e26 gets thrown up on some digital rights management programs.this really just means you are not allowed to record...ever increasingly thanks to the big corps like sony drm carrier signals are put into some broadcasts to overcome copying infringements.there still is a way to do this with the right equipment.some tv channels get revenue from their advert counts so they put these signals in to ensure that you can only watch at broadcast or catchup on certain devices.what I can't figure out is I can record anything whilst it's being aired and still transfer to older equipment but not anything with latest ios and certainly not with sony recorders.
Jan 26, 2015 | Toshiba RDXV60KB DVD HDD VHS Recorder
Since my comcast switched to digital I cant record !! Is this DVR compatiable with Comcast digital cable???
Yes,all DVR compatible with digital signal that included Comcast digital cable.U can't record because probally the program u tried to record it copy write protected.What did u tried to record?Just tried to record some plain show,If it is recordable than u know the deal.
Feb 02, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
My DVD recorder LG RH1858 isn't recording properly. It shows the message "record blocking sidnal are detected". Please inform.
Unfortunately, your recorder is picking up a signal in the broadcast that copy-protects the show. The recorder is programmed to forbid copying of protected material. Depending on the source of the copy-protection, you may be able to block out the copy protection signal with a hardware filter. One example of these would be the Sima CT-2 that is placed between the S-out of the receiver and the S-in of the recorder.
I hope this helps.
(One common sources with this issue: a DVR that passes on the copy protection to an attached DVD recorder. Particularly some of the new Satellite/Cable receivers with built-in DVRs. The non-DVR models of the products usually filter out the copy-protection.)
Mar 29, 2010 | LG RH177 DVD Recorder/HDD Recorder
LG RH399H
Jun 21, 2009 | LG RH1999H DVD Recorder/HDD Recorder
Feb 12, 2009 | Sony VRD-MC5 DVD Recorder
Panasonic DMR-ES30v Combo- Message of "Check disc for error"
Pay TV in Australia will record "no problem" BUT BUT when it is a pay per view or Box Office etc it will be blocked in a similar way as Macrovisin that is recognized in the encoding of the recording device that the signal is passing through. The result point blank displayed you are not allowed to record this program or it is blocked or distorted part of the way through the recording etc...
Dec 31, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Set HDD to master
The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
Hope this helps - good luck.
Jul 23, 2008 | Swann Communications DVR4-Alert Video...
LG RH1999H DVD Recorder/HDD Recorder Logo
379 people viewed this question
Computer Repairing
Computer Repairing
