Question about Panasonic PT-47WX52 47" Rear Projection Television
Convergence Hi My tv looks double layered with red and green out lines around everything I tried ti rest the conergence and the crosses will not line up and they are squiggly any suggestions Thanks sherri
    Genius:
  • 1,139 Answers
Hello sherri88,
What might be happening is that your convergence IC modules (STK392-110) are malfunctioning. This is a common problem in projection TVs. If you have a background in electronics you can replace these modules yourself however if you do not have a background in electronics, I would suggest that you take the TV to a qualified repair shop or have them come out and replace the modules. They may also want to do some troubleshooting to make sure that the biasing resistors and zener diodes are not damaged.
If you need anymore assistance, contact me.
I hope this helps
Thank you,
Shuttle83
Posted on Oct 17, 2007
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
The left side of the picture is distorted with a double image. The right side is fine. As things such as the stock symbols on CNBC scroll across from right to left on the screen, they start out looking...
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
Jan 12, 2011 | Hitachi 51GWX20B 51" Rear Projection...
Im seeing duble words,how can i fix it?
There should be a convergence adjustment on this set. It will have a "cross hair" type pattern
You adjust the beams so that the cross hairs turn white. I believe Green is not adjustable intentionally. The procedure is to adjust the vertical Red line until it alligns with the Green line. Then adjust the vertical Blue line until it lines up with the Red and Green. The line should turn White.
Repeat the procedure for the horizontal lines. When you return to regular viewing mode the double
images should be greatly reduced or eliminated..
Hope I've helped you,
Best Regards,
Mark
Dec 30, 2010 | Panasonic Televison & Video
I have a Panasonic HDTV and suddenly the colours went double!
hi, if you know little fixing tip's? here's my tip's sound's like converging ic's,gone bad. on the left board there's two a touched to a big heat sink.but before you start'.there's three wire connected to the board written. red .blue.and green.check for burn film resistor's on line red. replaced it with the same.good luck.
Feb 02, 2010 | Panasonic Televison & Video
Characters on picture look double and colors not lined up
HI, the convergence board or unit is failing at this point. you will need to replace the entire board in this case. most of the components are damaged.
The convergence board is the main regulator of the RGB stream. it also controls color focus as well. replace the convergence board asap.
Jul 22, 2009 | JVC AV-48WP30 48" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Hitachi Mo# 53uwx10ba double image
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Panasonic PT-47WX52 47" Rear Projection Television Logo
121 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
