Question about Simplicity for Children 4-in-1 Convertible 3045 Bassinet
The plastic slides for the front slide rail are not very clear in the manual on how they are to be placed. I have the Model # 8994 Simplicity Crib N Changer Combo. Do the slotted brackets go at the top or the bottom? Do the brackets with the hook and the spring clip go at the top or the bottom. Pictures and instructions in manual are not helpful at all.
Went to a department store and checked out a similar baby bed. I observed the assembly of the bed and was able to finish my baby bed.
Posted on May 26, 2009
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
Simpilcity Crib
The vast majority of the Simplicity brand cribs have been recalled. Here is the CPSC listing that includes the 8994 model # crib:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07307.html
In case you actually have a different model #, Here is the CPSC link that includes all Simplicity brand recall notices.
Returning the crip or getting a resolution for the crib you have depends more on where you bought it than anything else. Simplicity is not fully in business any longer according to the CPSC so you cannot obtain repair kits for these cribs.
We had a Simplicity crib, one of the Aspen models. We had bought ours at Wal-Mart. They have a pretty open policy when it comes to recalls. We returned ours this past summer for a full refund. We had bought it in 2002 so it was over 7 years old at the time.
If you know where you bought it, then checked with them to see what their policy is concerning recalled products, if you're not sure where you bought it then check with the major retailers to see who might have sold your model and what their policy is.
I would definately alert you niece to the recall. fF the dropside comes off at the bottom, the baby can really get hurt.
The recall is specifically an issue with the dropsides on these cribs. You can improve the safety of the crib by imobolizing the front dropside - make it where is cannot be dropped by screwing the front side into the side rails of the crib.
Jan 08, 2010 | Simplicity for Children 8994W Crib
Plastic pieces missing from the railing on the crib
please contact rockchic730@yahoo if you need detailed instruction on christina model 8996crp. i have the manual and i would be happy to help you out.
Jul 12, 2009 | Simplicity for Children 8994W Crib
Missing instruction manual for simplicity 4 in 1 crib, model 8994
I have the simplicity Ellis 4 in one if this is what you have i can scan it and send you a copy. What si your e-mail address
Jul 11, 2009 | Simplicity for Children 4-in-1 Convertible...
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Looking for teething rails for the Bethany James crib.
gud morning..maybe you can put a replacement of the plastic piece that slides or snaps on and covers the entire top of each side rail, you replace it by puting a cloths on it..and make sure that the child is safe.
thank you
Feb 20, 2009 | DaVinci Leonardo Crib
Simplicity for Children 4-in-1 Convertible 3045 Bassinet Logo
203 people viewed this question
Top Simplicity Baby Gear Experts
Scott Jelt
Scott Jelt
Greg Cann
Greg Cann
Jason Morris
Are you a Simplicity Baby Gear Expert? Answer questions, earn points and help others
