Question about Weather King 10AJA1801AH Air Conditioner
How much is a compresser for weather king ac unit
  • Weather King Master
  • 4,654 Answers
Be happy to help you and find an answer. Did your compressor burn out? What are the numbers on top of the compressor? How many BTU's or What is the the size? Tons of BTU's?
Posted on May 16, 2009
  • John Tripp
    John Tripp May 16, 2009
    I can help you find that compressor for a lot less than you see online. Just let me know and I will get you the email to our local refrigeration supplier.
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
I need a Weather King A/C repairman for my area. I live in New Orleans, La.
any AC Tech (in phone book) worth his/her salt will be able to repair your ac - but - you should be able to find a Weather King tech via the phone book or internet.
Good Luck!
Aug 09, 2011 | Weather King Heating & Cooling
HOW MANY TONS IS THIS UNIT WEATHER KING 10AJA4801AH?
It's a 48,000 BTU AC - so 48,000 divided by 12000 = 4 tons
Note: 12000 BTU = 1 ton of air conditioning
Jun 10, 2011 | Weather King 10AJA4801AH Air Conditioner
Weather King 10aja1801
The answer is yes however you will want to change the indoor coil in the furnace also.
You would look for a 1.5 ton matched set.
Jul 19, 2010 | Weather King 10AJA1801AH Air Conditioner
Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
May 14, 2009 | Weather King 12AJA4801AH Air Conditioner
What type of freon my ac uses
R-22, if it were R-410A then it would have a pink sticker on it near the service ports. You would know for sure.
Mar 24, 2009 | Weather King 12AJA4801AH Air Conditioner
Weather King AC
The motor of your air mover in the inside unit has failed.
It is responsible for circulating the air through the exchanger and your home.
This may be located in an attic space depending on the construction of your house.
Running the cooling with this not working could cause your outside unit to operate continuously or fail.
A more remote possibility is that the thermostat has failed and is only causing the outside unit to run.
Aug 19, 2008 | Weather King 10AJA6001AH Air Conditioner
Weather King 12AJB60a01 - Noisy Clang at Startup like hitting metal lockers
Sounds like the compresser is going out on the unit the noise is internal the winding would not have anything to do with that noise maybe valves going out
May 23, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King contact info
479-648-4900 is the main line to the factory in Fort Smith Ar. Hope this helps, RepairUSA
Sep 03, 2007 | Weather King 10AJA6001AH Air Conditioner
Open Questions:
See all Weather King 10AJA1801AH Air Conditioner Questions
Weather King 10AJA1801AH Air Conditioner Logo
227 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
