Question about HP OfficeJet 6110 All-In-One InkJet Printer
How do I copy a legal size document?
I slide my legal size document into the upper tray and fill the bottom tray with legal size paper, but when I push the black button, it stops copying the paper at the 8 1/2 inch mark.  Help, what am I doing incorrectly?
chrystal@sheldonmech.com
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
You need to change it in the menu, it's stopping because once it reaches the letter size the sensor detects that there is still paper there and jams.
Posted on Oct 23, 2007
  • Llenard Dalde Sep 06, 2012
    how?? help please.. i have officejet 5610 all-in-on..
I was trying the same thing and I was sure that somehow in the printer settings I changed it to legal paper size etc. But I tried this morning for an hour and couldn't get it to work and then I also tried on the actual printer in the menu, FINALLY i had a brain wave and went into the menu on the printer "reduce/enlarge" and went to "custom100%" and pressed "ok" it printed legal to legal hope this helps b/c there's nothing worse than knowing it should work and it doesnt want to and if anyone knows what tray is "tray 2" on the hp 7590 officejet pro let me know........ughhhh
Posted on Feb 25, 2012
Brother 9840 print on legal size paper
it seems that on your model you can only use legal size paper on tray 1 & 2, then you have to set the paper size.
here is a link to instructions for your model.
http://download.brother.com/welcome/doc002258/mfc9840_uk_usr_b.pdf
Feb 19, 2015 | Brother MFC-9840CDW Laser Printer
When I print a "letter" size document I have to push the green button to make it print. If it is legal it prints automatically to the legal tray.
Obviosly your magazine (Place of taking paper) of the printer is set to legal. The lights is lighting, couse the printer is telling you: You want me to print on letter, but I don have any letter, so please confirm that you want me to print on legal.
In order to avoid this set the printer to all types of paper available.
Jan 29, 2013 | HP LaserJet P2015dn Printer
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
We bought a canon pixma MX870 printer because it was supposed to be able to copy legal sized documents. The cassette on the one we received will not extend to handle Legal Sized paper, and the scanner bed...
Some info from Canon's site in the specs:
Max. Document SizeFlatbed:8.5" x 11.7"
ADF: 8.5" x 14"
This machine can only copy legal documents if you put them in the sheet feeder, not on the flatbed.
As for the paper supply, the cassette is indeed too small for legal paper. The automatic sheet feeder, however, will handle legal paper. That's the tray in the rear that you use for specialty paper; see page 17 of the Getting Started manual.
If you use the ADF and the rear tray, you can copy legal documents. That may not be as convenient a solution as you were hoping for, but it is better than no solution at all.
Feb 28, 2011 | Canon Office Equipment & Supplies
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Ricoh MP 5500 changes 8.5 x 11 documents to legal size on scan.
verify that the paper size shown on the display matches the size and direction of the paper in the respective trays, make sure paper side guides and rear backstop are tight against paper
Jan 07, 2010 | Ricoh Office Equipment & Supplies
I want to copy a legal size document to letter size
when you place the letter on the document feeder manually select the paper tray with letter paper in it and auto enlarge.. you will find the enlarge/reduce button at the right side of the bottom icons on the display..
Nov 10, 2009 | Gestetner DSm660 Copier
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
Dec 13, 2007 | Canon LaserClass 7000 Plain Paper Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
449 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
