Question about Nintendo Wii Console
Health and Safety screen is not showing.
When i open my Wii. My TV say: No connection detected. So i can't play it. Everything is plugged well. I can't send it to nintendo... it has a modchip in it. What to do!?
  • 6 more comments
  • tarkkanix May 16, 2009
    It his connected with the 3 colors cable. Directly in the TV.
  • tarkkanix May 17, 2009
    It is plugged well i'm not idiot :P
  • tarkkanix May 18, 2009
    Yes. Like the day it was before.
  • tarkkanix May 20, 2009
    Yes it was before.
  • fplqnewc
    fplqnewc May 11, 2010
    So you installed the modchip and now there is "No connection detected" on the TV? Did it ever work with the modchip?
  • fplqnewc
    My apologies for not phrasing my question well, I am just gathering information to see if I can help. I was referring to the different modes that your television can be in. When the television mode is on TV it uses the coax cable but when it is in mode Video1 or Video2 it uses the 3 color cable. The different modes can usually be accessed by the remote but also from a menu button on the television. Have you checked these yet?
  • fplqnewc
    What about the TV, is it set to either Video1 or Video2 (depending on which input you have plugged into)?
  • fplqnewc
    Are you going through Video connections or coax?
  • 40 Answers
I have done some review with a lot of the Wii problems and I don't think it is the modchip that is causing the problem.  There are many reported problems with unexpected failures of the Wii.  If you haven't already tried to, I recommend unplugging all the cables from the back of the Wii. let it set for about 10 minutes.  Then, plug in the power cord and the video cable to the tv and see if you get a picture.
I had to do this to ours after it wouldn't respond after a lightening storm.  We lost power, but after the power came back on the Wii wouldn't even turn on.  I thought it was damaged and was going to send it back.  We tried unplugging everything as I said above and it started working just fine after that.
Posted on May 24, 2009
My wii will turn on, but nothing shows up on the screen
Good news i had same problem and what i found out was that the wii bricked up an easy fix is to unplug ur wii from all cables then after 3 minutes plug only the power cable and see if ur wiimote connects but before dat remove sd and usb if the wiimote connects but u getno display then u have t afjust ur screen resolution hope this helps :)
Jul 03, 2012 | Nintendo Wii Console
Tip
How to connect you Wii to your TV, Out of the Box.
After getting everything out of the box, decide on where you want to put your Wii. It should be near your TV and near an electrical outlet. You can either lay the Wii flat or sit it on its side. If you’re laying it flat, move on to step 2, Connect the Cables. If you want to place the Wii in a vertical position you should use the Wii Console stand, which is the gray base unit. Attach the console plate to the bottom of the stand, put it on your shelf and then place the Wii on it so the beveled edge of the console aligns with the beveled edge of the stand.
There are three cables that connect to the Wii: the AC Adapter (a.k.a. power cord); the A/V connector (which has three colored plugs on one end); and the Sensor Bar. The plug of each is distinctly shaped, so each cable plug will only fit in one port in the back of the Wii. (The two small, same-sized ports are for USB devices – ignore them for now). Plug the AC Adapter into the largest of the three ports. Plug the Sensor Bar plug into the small red port. Plug the A/V Cable into the remaining port.
To connect your Wii to your television, find the sockets on your TV that, like the A/V Cable, are colored yellow, white and red. The sockets are generally on the back of the TV, although you might also find them on the side or front. You may have more than one set of ports, in which case you can use any of them. Insert each plug into a port of the same color.
The sensor bar can be placed either on top of your TV or right below the screen, and should be centered with the middle of the screen. There are two sticky foam pads on the bottom of the sensor; remove the plastic film covering them and gently press the sensor into place.
Next, simply plug the AC adapter into a wall socket or a power strip. Push the power button on the console. A green light on the power button will appear. The remote comes in a rubber jacket, designed to protect it, which you will have to partially peal off in order to open the battery door. Put in the batteries, close the battery cover and pull the jacket back on. Now push the A button on the remote to make sure it is working (a blue light will appear at the bottom of the remote).
The Wii remote that comes with your Wii is already synced up, meaning your console will communicate properly with the remote. If you have purchased any additional remotes, you’ll have to sync them up yourself. To do this, remove the battery cover from the remote and press and release the red SYNC button inside. Then open the little door in the front of the Wii where you will find another red SYNC button, which you should also press and release. If a blue light goes on at the bottom of the remote then it is synced up. When using the remote, slip the Wii remote wrist strap around your hand first. Sometimes when people are waving their remote around it slips out of their hand and breaks something.
Turn on your TV. Set your TV input for the input channel your Wii is plugged into. This can usually be done through a button on your television remote generally called “tv/video” or “input select.” Read any onscreen text. This will be either a warning, in which case you can press the A button, or a request for information, such as whether the sensor is above or below your TV and what the date is. Point the remote straight at the screen. You will see a cursor similar to the mouse cursor on a computer. The “A” button does the equivalent of a mouse click.
Once you have answered all the questions you are ready to play games. Push a game disc into the disc slot; the illustrated side of the CD should face away from the power button.
The main Wii screen shows a bunch of TV screen-shaped boxes, and clicking on the top left one will take you to the game screen. Click the START button and begin playing.
on Feb 15, 2010 | Video Game Consoles & Games
Greetings! Once the Wii console is powered on,a display " Warning-Health and Safety and etc.Press A to Continue " showed-up on the TV screen. When I pressed "A" on the remote or just...
you are getting Black screen While using your nintendo and nothing else Right .................
if so then
u can download repair guide available in net ....... you can download it and solve your problem its a big process but if you do correctly according to the guide then you can fix this.......
Click here to download repair guide
Dec 14, 2010 | Nintendo Wii Console
How to connect a tv to a wii
Feb 15, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
It's been ahile since I've used my WII. All the
I'm not certain, but it really sounds like you might have the cable plugged into the "out" instead of the "in."
The best thing to do would be to first try using the Wii on another TV. This will help establish if it is the Wii that is the problem or something else.
If it works fine, then it is not the Wii. If it doesn't work, then it must be the Wii or the connectors.
To complete the troubleshooting process, make sure the VCR and TV both are able to show clear images (play a tape in the VCR, I guess). If they both show clear, and the Wii worked on another TV then your problem is definitely in the connection. Either it is misconfigured or a wire is faulty.
Jan 03, 2010 | Nintendo Wii Console
Frozen on health and safety screen, without words on bottom "press a button to continue"
Did you download the homebrew channel? or tried to?
if you did then that is probably why it freezes
May 22, 2009 | Nintendo Wii Console
The screen goes blank, wii emits buzzing noise.
refrain from playing for a few days.
its what you call a black screen of death. it will keep happening until your wii stops if you dont refrain from playing for a while and obey the health/safety rules (sometimes the wiis pass becuase the health/safety rules hide the bsod) [health/safety rules: take a ten - minute break every hour.] BE CAREFUL WITH YOUR WII IT IS VERY FRAGILE IF IT GETS A BSOD!!!!!!! {fragile=easily damaged INTERNALLY}
Feb 17, 2009 | Nintendo Wii Console
Cant add a controller
I had the same problem and called Nintendo support. They had us unplug the wii console for 30 seconds, plug it back in and start the system back up. BEFORE pressing the A button on the health and safety screen, we needed to take the battery cover off of one remote, press the red sync button, then quickly press the sync button on the front of the wii console (in the front - you have to open the flap). Once the single blue light was on at the bottom of the remote, do the same with the other remote (press the sync button on it and then on the wii console). Then the second blue light should be lit on the second remote. Hope that helps!
Nov 29, 2008 | Nintendo Mario Kart (Wii) for Wii
Nothing Shows up on the Video Screen When I power up Nintendo Wii
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Oct 29, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
153 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
