Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Ice dispenser all of a sudden it only dispenses crushed ice
  • ronaldp Oct 17, 2007
    Thanks for the prompt reply.
    Here's what I have determined is the problem. The gizmo that turns the auger one way for cubes, and the other way for crushed ice, is only turning in the crushed mode.
    Are there fuses in there?
    Thanks for your help.
Voila!
As I prepared to remove the back plate, behind the ice bucket,I put my finger into that square hole that the steel rod goes into.
The plastic sleeve fell down(it must have been stuck in the up position somehow) I replaced the ice bucket and out comes the ice cubes.
Thanks for the expert advice. not to mention the saving of a $60. service call.
Posted on Oct 17, 2007
  • 473 Answers
On the bottom of the ice bucket it has a metal rod that fits into a square hole in the back of the freezer.  Behind that square hole is a solenoid that actuates the rod on the bucket.  Take the bucket out, shut the door and press for ice.  If you hear a loud clunk noise then that is the solenoid moving up and down.  If you don't hear that noise then replace the solenoid.  Sometimes when the bucket gets taken out and put back in the rod is underneath that solenoid and doesn't let it actuate the rod.  If you find the solenoid is working make sure the solenoid is in the down position then put the bucket back in.  Let me know what you find.
Posted on Oct 16, 2007
  • Craig Shelton
    Craig Shelton Oct 17, 2007
    The auger will only go in one direction.  That solenoid acutates the rod on the ice bucket which will engage the blades for crushed ice or disengage for cubes.
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
Why are my ice cubes dispensing faster than my crushed ice. I changed the auger assembly and crush ice is still slow coming out of dispenser.
Hello Theresa;
My name is Peter. I am a retired field service refrigeration technician.
I have gone on many a service call in regards to this issue. People like their crushed ice.
The auger was not the problem. It is the nature of the beast.
Regular ice cubes have more density (Heavy) and exit through the door dispenser with no problem.
With crushed ice, shaved chips they are lite. When you dispense crushed ice the ambient room temperature (warm air) creates condensate and bines the crushed ice together. Fragments of the crushed ice block the dispenser flapper from closing all the way. The flapper remains a little bit open and ices up.
The manufacturers recommend after you run crushed ice that you run cubes through your dispenser to clear the crushed ice fragments.
Well, that solution is from engineers sitting in a office.
The solution is, from a old experienced field technician is: Reach up and wipe the flapper with a dry cloth. Look up and make sure the flapper is completely closed.
If you need a tech call me at 414-306-1362. Glen Burnie, Maryland, USA
Dec 30, 2014 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
244 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
