Question about Standard Oregon Chainsaw Chain For Stihl Chainsaw 16" Bar Length 60 Drive Links 3/8 0.05 Gauge Chiesel Chain
Length of bar on a Stihl 015 chain saw
Where do you measure the length of the bar from? From the center of the bolt that holds the bar??
    Sergeant:
  • 302 Answers
Measure from the very front edge of the bar back to the gripper teeth
Posted on Aug 14, 2009
What other chain can i use on a stihl 025
You need to know three things about your saw as to what chain will interchange....1. Pitch of the chain. 2. Guage of the guide bar. 3. Number of chain links.
Your little 025 Stihl wil probably have an .050 guage and a .325 pitch. The standard guages for small saws are .043, .050 with .058 and .063 being reserved typically for the larger displacement saws.
The pitch is the length of three links, divided by two and the number of links is kinda self-explanatory. (The 025 USUALLY is set up for the .325 pitch.)
Any chain that matches the three measurements for your respective saw should interchange. Hope this helped instead of adding to the confustion......
Sep 18, 2015 | Stihl Garden
What Stihl chain should actually go with this bar?
3003 001 6113
3003 Is for the 048
001 (internal Logistic number)
6113 the last indicates bar length which you already know as 25"
It for 3/8" chain.
All need to know is its gauge which can determined from the your chain's drive links number.
1 .043" 1.1 mm
3 .050" 1.3 mm
5 .058" 1.5 mm
6 .063" 1.6 mm
0 .080" 2.0 mm
Jan 17, 2015 | Stihl Garden
What should the coil gap be on a stihl 034 chainsaw
the coil gap on that saw is 10-15 thousandths
find parts and details about Stihl at dealers like www.arcolawn.com
Joe
Jan 01, 2011 | Standard Oregon Chainsaw Chain For Stihl...
I have a Stihl chain saw an O8S. The carburetor
I would try here first. I have had good luck getting old parts here. I hope it helps you out.
www.jackssmallengines.com/stihl_index.cfm
Jun 17, 2010 | Standard Oregon Chainsaw Chain For Stihl...
Putting chain on saw
I am assuming your saw has an outboard clutch (most Macs do).
Please see page 16 here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1140247-95.pdf
It is possible to install it backward look colsely at the orientation in the second illustration from the bottom, left column.
New chains stretch Please for your safety watch it and tighten when needed.
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Jan 16, 2010 | Standard Oregon Chainsaw Chain For...
Hard to start when hot --- ms210 stihl saw
Check the plugs for fouling, or whiting. Could need fuel air mixture re adjusting. Good Luck
Rich
Dec 01, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Isit possible to get parts for a stihl 076 anymore
there is a guy on e-bay known as dozerdude that sells used parts for Stihl saws
Nov 30, 2009 | Standard Oregon Chainsaw Chain For Stihl...
How to adjust chain bar oiler
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl chain saw
shut off the engine
pull out the hinged clip and loosen the wingnut
turn the adjusting wheel clockwise as far as stop. (on top of the adjustment wingnut).
tighten down the wingnut firmly by hand
fold down the hinger clip.
go to the following link, if you need the users manual.
http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
Apr 09, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Standard Oregon Chainsaw Chain For Stihl Chainsaw 16" Bar Length 60 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
400 people viewed this question
Top Standard Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
