Question about Hotpoint Aquarius WF210 Front Load Washer
Noisy drum the drum seems really loose and makes a grinding noise; have took lid off to see if springs have gone but all anchor points are ok it sounds like a bearing is it posss to change them or are they a part of the drum
  • abody Oct 19, 2007
    thanks 4 trying the drum was shot 2nd drum in 3 years my advice dont buy hotpoint washing machines
  • Anonymous Mar 31, 2014
    the drum sounds as if the barring have gone on the motor
  • 363 Answers
You are describing shot bearings.
It should be perfectly possible to replace the bearings if you are able to press them out of the spider.
The usual fix is to obtain a replacement spider, your local domestic appliance repair shop should be able to supply an exchange unit.
If you attempt the repair you should check that the drum has not damaged the water heaters as it may have been these that it was grinding on.
Posted on Oct 16, 2007
  • Martin B
    Martin B Oct 19, 2007
    The drums are welded stainless and dont normally fall apart.
    I'm interested in this, any possibility you'd describe exactly where it failed.
    Thanks, Martin
Hi my machine is really loud sounds like is gonna smash in to bits when spining also when empty if you spin drum with hand feels like its rubbing on something ??? my question is is it worth repairing cos...
Is your load evenly distributed when spinning? The drum will not spin freely when empty and pushed by hand so don't worry about that. Run a full cycle on empty to see if it still makes the noise. If so you probably need a visit from the repairman.
Feb 02, 2018 | Indesit Washing Machines
Servis 1200 very noisy in spin modes. Inner drum seems to be very loose and wobbly. Noise sounds like a roller with flat spots running on the drum, or a very bad (failed) bearing. Machine is 12 years old,...
the bearings have gone, if the drum can be split, remove complete drum and replace bearings, if you dont think its something you can do, dont attempt it, but to be honest, its realitivly easy
Sep 09, 2013 | Washing Machines
Hi my hotpoint auarius 6kg wma58 is making knocking noises but i check every thing and is working fine and the belt is ok i noticed there small dent marks inside either side of each other where the drum...
Most times with Hotpoint the inner drum becomes loose due to faulty Bearings ....Also the concrete weights bottom ,becomes loose and Noisy....some times one of the small top springs snap.....Hope this helps
Feb 24, 2011 | Hotpoint Washing Machines
I have a Kenmore [2005]front load washer that vibrates severely when in high spin and is quite noisy. I have had the top panel, back panel, and bottom front kick panels off and I can not find any obvious...
you may need to change the bearing on the drum easy way to check is while the door is open try to manually spin it with your hand if you hear a grinding sound then the bearing is gone
Nov 05, 2010 | Kenmore 44102 Front Load Washer
UBNORMAL SOUND DURING DRY SPIN
Washing machine is noisyIt's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently.
Here's a general guide though -
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
  • Coins or other obstructions trapped inside the tub under the drum can make horrendous noises as they get tossed about on spin. They often don't make the noise unless laundry is in though. Look out for obvious dints and creases in the drum itself as evidence of a coin or similar stuck inside although be aware that it only shows there's been an obstruction in at some point and the coin could have fallen into the sump hose or filter and not actually be the cause of the noise at this time
  • Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as the coins get tossed around inside. Often, spinning the drum by hand will not reproduce the noise in the case of coins because the coins drop to the bottom of the tub and lay flat when the washing machine isn't spinning
  • A light scraping or ratchety noise when the drum is turned by hand is commonly a bra wire trapped between the tub and drum. They can often be removed from underneath with the sump hose taken off. It's always worth checking that the wire isn't poking through one of the holes in the drum which can be pulled back out from inside the door. It's rare, but I've retrieved 3 or 4 this way over the years.
  • A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
  • A knocking noise can be a loose tub weight. This would normally be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early enough
  • Sometimes a badly worn drive belt can cause a surprising amount of noise. I've even come across some where i was convinced the drum bearings were gone until I took off the belt and spun the drum by hand to find no noise.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk. If you have a specific noise you are concerned about, either call an engineer
Apr 11, 2010 | Samsung Washing Machines
Hi ive got a wf840 washer and its got noisey lately so ive had a look and it feels as if the drum inside has came loose so i took the top of to have a look and there seems no way in to tighten it up the...
There is no adjustment provided for adjusting or tightening drum.
The drum is held in place by 2 springs at the top of the drum,
Sometimes these can break
At the bottom end, the drum is fastened to the base of the washer by 2 shock absorbers, these can break loose or wear.
These can all be replaced with out removing the interior drum assy.
The other possibility is that the drum bearings have failed, this would also make it very noisy.
Feb 21, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Very noisy on spin
hello there.....the noise you hear is most likley due to failed drum bearings or something trapped in the drum....test as follows....isolate machine....open the door...test the drum for up and down lift...there should be no movement at all....if all is well here...remove the lid and remove drive belt....spin the drum by hand and listen for any bearing noise (rumble). or metallic sound of something trapped in drum..if all is well here refit the lid temp...Then select spin and start machine...if motor is noisy then the problem is with the motor bearings
regards Sir Galahad
Sep 21, 2009 | Hotpoint WMA64 Front Load Washer
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Eurotech front loading washer, noisy on spin cycle with load.
Hi, could be one of at least two things - if the inner drum can be moved up and down by hand more than an inch when you grab it through the open door it could be the drum bearings that have failed - not good. Usually accompanied by a grinding noise and dirty specks on the clothes.
If the outer drum is really loose in the casing - check with machine unplugged and top removed - then one or more of the very strong springs at the top or the telescopic dampers at the bottom might have come off or broken from it's mounting.
Hope this helps!
If it doesn't, please hold off the rating button and add a comment with more details so I can try to help you further. Cheers, D
Mar 26, 2008 | EuroTech EWF172 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
148 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
