Question about Water Pik Waterpik& Elements& Handheld Showerhead
No cold water in bath shower
Sink and toilet have good cold water supply single handel style when turn to cold side no flow
    Problem Solver:
  • 5 Answers
No flow at all or very little
Posted on May 18, 2009
What is causing air in my cold water line and how do I fix it?
try running all the water in the whole house at once. all toilets. outside faucets, washing machine, ect...
assuming you have no leaks.
Aug 25, 2014 | Home
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
Why does water suddenly go cold during shower? It only happens in master bath... guest bath shower does not cause same problem. I have to go outside and unplug and plug back in heater to get it to start...
Try running the hot water in the sink while you have the shower. If the water in the shower stays hot, then the problem is not enough flow through the water heater to keep the heater running. I am guessing that the master bath is further away from the water heater than the guest bath. If not I would check the shower nozzle in the master bath to see if it is clogged a bit or if it is a water saver nozzle because this will slow down the water volume and then cause the water heater to shut off the heat.
Feb 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I have a single handle kohler bath tub faucet I am not getting any cold water out. i have taken this apart and found nothing that i can see that would impede the flow of water ?is the mixer valve at the...
If the faucet was working before and then just stopped, it is the mixing valve or a clogged supply line.
turn the water off and remove the mixing valve. Turn the water on and see if you have good flow from both hot and cold ports inside the faucet.
Caution- this procedure can get messy, close the shower curtain or door.
Call Kohler and ask for a new mixing valve for free.
Sep 12, 2010 | Kohler Plumbing
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
Doesn't let any hot water through
You need to check the age of your water heater. If it is pretty old, it can be sloughing off debris that can get caught in the hot side of the faucet. You will need to turn the water off to the unit, remove the guts. While someone is turning the water on slowely, flush out the the valve. Take a flashlight and check for debris that is caught. I have spent a few hours digging out debris from water heaters before. After you have done this and your still not getting water, check the scald gaurd for the right temp. Typically these don't just "jump" out of adjustment on their own because they have a small retaining washer that holds them in place. I doubt it is the scald guard if everything was working just fine before. Plus, the bath faucet has the most flow than any other faucet in the house so this will be the first place that debris will usually travel. Good luck
Mar 29, 2009 | Delta & Single Handle Shower Faucet
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
My shower has a delta monitor single faucet. And the flow has diminished so much that I am only getting few drops. The house has a lot of water pressure. What can I do?
Sounds like you have lost pressure on one side of the valve. ( either hot or cold ) Or the cartridge has gone bad. If you have hard water if probably is the cartridge. There are a couple of different series for your style of faucet.
The reason why you only get a few drops is the cartridge is pressure balancing. It is a safety device which prevents scalding if one side of the supply shuts down.
Please rate this response and Good Luck, Phil
Dec 30, 2008 | Delta T13420 Chrome Classic Single Handle...
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Water Pik Waterpik& Elements& Handheld Showerhead  Logo
590 people viewed this question
Top Water Pik Home Experts
Donni Steen
Are you a Water Pik Home Expert? Answer questions, earn points and help others
