Question about Kyocera FS-1030DN Printers
Printer KYOCERA FS-1030D not geting connected to my local Netwok.
I Have a Printer Model KYOCERA Ecosys FS-1030D and i want this printer to connect to network. its having a network card came along with printer but when i printed the test page its doen't show any default IP address and to that i happen to see that its DHCP option is Set to OFF mode. The Subnet Mask is shown as 255.255.255.0.
Can you please help me out how to get this printer connected to my local network.
Please advice me how to go about.
Thanking you in advance.
Mr. Lewill Gomes.
  • 2 more comments
  • itmanager Jun 12, 2009
    Hi Versa093,
    I was trying to connect to the web site you sent me here abovehttp://www.kyocerasupport.co.uk/index/do... but, unable to find any solution is there any other site were you can get more info about this problem.
    Thanks in advance.
    Lewill.
    Hi Versa093,
    Thanks in advance.
    Lewill.
    Hi Versa093,
    Thanks in advance.
    Lewill.
    Hi Versa093,
    Thanks in advance.
    Lewill.
  • 46 Answers
I cannot remember the name of the utility but I know on the new drivers for the newer machine it is built into it it discovers the machine baised on its mac address and you can change / set the ip from there.Try some of the utilities from the kyocera support sitehttp://www.kyocerasupport.co.uk/index/download_center.html
Posted on Jun 11, 2009
  • versa093 Jun 12, 2009
    If you download the latest full driver (44.98mb) http://www.kyocerasupport.co.uk/index/do... unzip and run the set up
    Select the 1030d and network, standard tcpip
    It will the use the discover utility in the install to find it. If this wont work try to reset the network card to factory default.
    If you are unable to communicate with the IB-21E, it may be reset to factory defaults by changing the onboard jumper arrangement. Proceed as follows:
    1.
    Turn printer power off.
    2.
    Remove the IB-21E from the printer.
    3.
    Locate the jumper terminals on the board. Note the normal position of the jumper in reference to the terminals.
    4.
    Remove and fit the jumper so that the pins of terminal SW2 are short-circuited.
    5. Insert the IB-21E in the printer.
    6. Power up the printer.
    7.
    8.
    9.
    Remove the jumper from SW2 and reset it to the normal position as shown in Figure 1 above.
    10.
    Plug in you network cable and power on the machine see if it gets a network address from dhcp
    Then run the driver set up again
How do I clear the memory on a ECosys FS-C2126 Copy/printer
it is under mode 21, you need to login first to maintenance mode by punching the numbers 1087 1087. then select the number 21 then hit start. you will be able to clear the memory .
Jun 10, 2015 | Copystar Kyocera FS-C2126 MFP Color...
What location on the kyocera Ecosys FS-1030D is the correct place to insert the envelope.
Pull the multipurpose tray open in the front of the printer. There you will find adjustable side guides
Jul 19, 2011 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
My pc hard drive is broken, i have replaed the hatd drive but i cannot find the software to reinstall my printer model FS 1030D
Go here, fill in the blanks and download the drivers you need.
http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp
Jan 05, 2010 | Kyocera FS-1030D Laser Printer
How do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Nov 19, 2009 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
Kyocera FS 1030D Flashing Lights
you are out of toner and you have a paperjam
Jun 16, 2009 | Kyocera Mita FS-1030D Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
I cannot take prinout from kyocera FS1030D from my laptop
make sure you have the correct driver for your laptop operating system and you have a usb2 cable
Dec 03, 2008 | Kyocera FS-1030D Laser Printer
Top 3 lights blinking on printer
The flashing of the LEDs you describe indicates a error. If you call the Kyocera Help Desk they can tell you what the error is based on the order and color of the LEDs. They can be reached at 800-255-6482.
Aug 18, 2007 | Kyocera Mita FS-1030D Laser Printer
Kyocera FS-1030DN Printers Logo
3,574 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
