-DVD Drive won't read or burn blank -DVD media
I have a Gateway M675 Notebook: My problem is with the HL DT ST DVD-RW GWA4040N Optical drive. This drive does everything its supposed to do except read blank -DVD media. I've already tried about 5 differing types of name brands 4 of which previously worked with no problems. Before I find myself needing to flash the drive or the BIOS unnecessarily with new firmware, which to me looks very risky anyway, I'd like to weigh any other options. A system restore is out of the question since this problem is approx. a year and a half old. I thought of replacing the drive but the forums I've been reading haven't offered any conclusive answers. I've already uninstalled and reinstalled the drive and the IDE channel/controllers to no avail. Apparently there isn't any support available for this from LG/HLDS or the manufacturer since the whole Gateway/MPC debacle. ------------------------------------------------- Processor Intel Pentium 4, 3000 MHz 800MHz external bus BIOS Gateway 39.02.01 02/20/2004 Memory 1024MB physical Drives C:\ (NTFS) 76316MB total, 5429MB free D:\ CD-ROM/CD-RW or DVD Drive E:\ (NTFS) 76316MB total, 5408MB free F:\ CD-ROM/CD-RW or DVD Drive Operating System Windows XP SP3
  • 1 more comment
  • musicmee1 May 16, 2009
    Thanks for responding. The drive has always been able to recognize, read and burn a multitude of minus media up until last year when I just gave up looking for solutions. (CD's and DVD's). Now it does everything but read blank minus DVD's. If it doesn't read it, of course it won't burn it. When I go to the drives' properties, while the blank disc is in, it reads as full. This from three new spindles of Sony, TDK, and Imation.
    As far as the BIOS goes I've emailed Gateway as to the correct one and I'm waiting for a response. It looks like there are two available but I'm not sure what the PIR/PRR desigations mean. I can't find those designations anywhere on my notebook hence the aprrehension. I've read what the wrong BIOS can do and I can't afford it!
    Now the problem with repacing the drive is that what I've seen so far online is that it isn't necessarily the drive but the firmware. Many have complained about this series of drives from LG/HLDS with no apparent fixes, but seemingly these are problematic drives and I don't want to buy another just to repeat more of the same. (Sorry for the long email. Just trying to give as much info as poss.)
  • pumpguy05 May 22, 2009
    I have the same problem
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    You can try a new drive as an option and upgrading the BIOS is never a problem as long as you get the right version for your laptop and I would help you with that. Have you ever been able to get that laptop to read blank dvd media??
  • Computers & ... Master
  • 16,648 Answers
Just replace the drive, that unit is old and it has a bad reputation.
Posted on Mar 03, 2017
cropp
  • 377 Answers
SOURCE: No Audio
oke
go to
http://www.driverfiles.net/page,show,317,,thinkpad%20600e%202645,search.html
oke
Posted on Mar 28, 2008
SOURCE: Sony DVD RW AW-Q170A Burning Problem
1. pl confirm ur drive as as sony as AW-Q170A
2. Download both file necflash_wingui.zip and 113bt_rpc1.zip
3. If ur not sure about drive being master or slave turn all the IDE to PIO mode. Pl remember flashing will not be possible if in other mode.
4. Unzip the zip file
5. Run necflash dump the firmweare file at safe location and flash the bin file with 113Bt_prc.bin.
6. Reboot in safe mode. Restore IDE to original mode.
7. Reboot and start normally. Bingo prob is solved
Posted on May 01, 2008
mdsaeed67
  • 849 Answers
SOURCE: The HP Presario A900 shuts down within 5 minutes of start up
THE CPU FAN SEEMS TO OUT OF ORDER.
Posted on Nov 26, 2008
  • 82 Answers
SOURCE: DVD Rom Drive Won't Play Some CDs...
Couple of possiblilities. Hardware or software.
You can go here to get the latest drivers for your system , just put in the serial.
http://support.gateway.com/support/drivers/dlcenter.asp
Or here
http://support.gateway.com/support/drivers/ddaStep.asp?platform=10022&model=10651&os=&type=&st=browse
If it is listed correctly in the system , it is probably starting to fail. You can try cleaning the laser lens GENTLY with a cotton swab and alcohol.
Also you can try and flash the firmware of the drive. The format of DVDs change slightly over time sometimes making newer ones unreadable. Here is a site with flash utilitys for your drive.
http://tdb.rpc1.org/#GSA4082N
If you still have issues , you may need to replace the drive. Cheapest one I could find was $179
http://www.notebookparts.com/products/description.php?II=11272
Might be cheaper to go with an external one if you can get one cheap.
Posted on Mar 04, 2009
  • 9 Answers
SOURCE: Combo Drive LG : CD is not designed to run on Operating System
The 'autorun' sequence to run the disc might have been made for older operating systems. But that should not stop you from installing the driver for the 330 IDSL modem.
1. Go to start-> My computer. Locate your G: drive with the disc inside and right click on it. Choose explore and see if this allows you to view the contents of the disc. If there is a generic application labeled setup.exe execute it. If the application loads the driver for you then your in luck. If not then onto #2.
2. Your modem has been out for a while and has new drivers for it. You can always type in a search "SpeedTouch 330 IDSL modem" and download a more recent driver off the internet.
Example of what I found: http://downloads.zdnet.com/abstract.aspx?docid=458129
Posted on Mar 05, 2009
HL-DT-ST RW/DVD GCC-4244N Will this burn a DVD ?
This model drive is a combo DVD drive.
It is a CD read/write drive and a DVD ROM drive (only read DVD disc but not burn disc).
Mar 31, 2011 | Computers & Internet
HL-DT-ST RW/DVD GCC-4243N wont burn dvds
Try uninstalling the Driver in Device Manager: in XP or earlier: Start/Control Panel/System/Hardware Tab/Device Manager, or in Vista & 7: Start/Control Panel/Device Manager.
Once in Device Manager click on the + sign that is in front of 'DVD/CD ROM drives' to open it up, then right click on the model of the Optical Drive in question.
Click Properties/Driver Tab/Uninstall (Advanced) & this will remove the driver if it is corrupt. Restart your system & the Hardware Manager will recognise the Optical Drive & install the necessary Driver.
If this doesn't solve your dillema then I hope that you have a warranty. Good luck in trying.
Kindest regards,
Ste
Apr 02, 2010 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
I have a HL-DT-ST DVD-RW GWA-4040N drive in stalled in an emachine Laptop, the drive will read data,cds music and dvd movies, but can not burn either cds or dvd...Depending on which program i use for...
well there could be a few things you can try
1) update the firmware and see if it works any better
2) try brand name DVD-R disks and CD-R disks
3) try an updated hack firmware such as these http://tdb.rpc1.org/#GWA4040N
4) try Nero Lite. it is free and it supports almost any drive. http://www.nero.com/eng/downloads-nero9-free.php
I would not worry about the driver as they normmally would not need any.
Dec 16, 2009 | E-Machines emachines (emachinees) CD-ROM...
My LG combo drive HL-DT-ST RW/DVD GCC-H23Ndoes not
The lens for reading dvd is busted and needs to be replaced that is why it no longer read dvd.
Oct 31, 2009 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
HL-DT-ST DVD+RW GWA 4164B DOENSN'T WORK
open explorer and go to 'My Computer'
right click the DVD/CD-ROM Drive
click on the tab labeled 'Recording' (usually on the far right)
click the option that is labeled 'Enable CD recodring on this drive'
...and POOF, magic happens...
Dec 31, 2008 | Computers & Internet
LG HL-DT-ST DVDRAM T10N ATA DRIVE
Various issues can cause drives to occasionally balk at writing optical discs. These run the gamut of physical, hardware, and software troubles.
Inappropriate or dirty media may be to blame. Make sure to match the type of recordable disc to the drive, and check each disc for fingerprints or other contaminants. If a disc is dirty, wipe it with a clean, soft cloth in a straight line from the center hole outward. Try a quality optical drive cleaning disc if you suspect dust contamination on the drive’s laser lens.
Some discs don’t perform well with certain drives, even within their rated speeds. Try recording at a slower speed and then with a different brand of disc. Also, on PCs, verify that the temporary file storage area on the hard drive used by the burning software has enough free, defragmented space. Allocate at least 5GB for a DVD (9GB for a double-layer [DL] disc) and about 1GB for CD burning.
Feb 28, 2008 | HP Pavilion dv6000z Notebook
HL-DT-ST-DVD-RWGRA-4120B cannot burn
Drive might be dead. Try another drive to eliminate the drive as being the problem. Also try DeepBurn writer software.
Nov 22, 2006 | Hitachi LG GSA-4120 DVD+-RW/RAM 12x Burner...
Computers & Internet Logo
247 people viewed this question
David Payne
David Payne
