Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series 110.26892690 won't agitate or spin
Motor seems to be working but no action.
  • iph0410 May 17, 2009
    Kenmore 80 series washer. Cold water not working. Cleaned both hot and cold screens. Please help?
  • 975 Answers
It seems like the MAIN BELT DRIVE broke , just replace it , and youre good to go , AJ
Posted on May 16, 2009
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
My ken,ore 80 series washer agitates ok and seems
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Two things to check.
It sounds as if the tub isn't getting full power from the transmission for spinning and/or the pump/hoses are damaged or blocked.
1. Remove the cabinet.
See the following.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=7777818c689b6ece38ca9884721fffc7
and check the hoses / pump.
2. If they are OK, the problem may point to the Motor Coupler. See the following for how to check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
3. If the pump and Motor Coupler are OK, the problem could point to the clutch.
See the following for how to pull the pump, motor and transmission.
You don't have to remove the tub!!
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the clutch bands are worn, you don't have to replace the entire clutch. Sears / Whirlpool have a band replacement kit, a lot less expensive and easier to install than a new clutch.
Jan 17, 2010 | Kenmore Washing Machines
Kenmore 80 series not agitating or spinning,making racheting soun
You have a broken coupling that links the motor and transmission. Call around your area for estimates. It is a pretty straight forward job so most technicians should be able to give you an estimate over the phone. Most likely between $150.00 and $200.00.
Aug 01, 2009 | Washing Machines
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
320 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
