Hello friends!
I have a cap2761ewo washing machine.
I have replaced the electronic control panal board.
The price is pre programmed to $1.00
How do change $1.00 up to $1.50 on the electronic display panal.
Please help. Thank you.
I have a whirlpool cap2761ewo. I replaced the electronic board. The pre programmed price is $1.00 I want to change the price from $1.00 to $1.50. I have mislayed the manual. Please help. Thanking You!I have a whirlpool cap2761ewo.
Hello. Thanks so much for your answer. I understand how to set it up to take more coins.
Problem is. I want to up the electronic display for the price of usage. From $1.00 to $1.50.
I did it about five years ago with my two washers and one dryer, but I have forgotten how to and I have lost the manual. It is easy like setting up the display on a a microwave, but it beats me.Hello. Thanks so much for your answer. I understand how to set it up to take more coins.
You can't post conmments that contain an email address.
You need to take the coin slot out by using a socket wrench. then you
need to flip the slot over and take the screws off. there is going to
be two more screws to unscrew. take off that piece and also the claw
like coin catcher. form here on out you should be able to remove as
many slots as you need to.
We try to find user manual for your model but there are no user manual for your model, if you want to oder your manual so oder tham from below link - http://owneriq.net/
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
31 Oct 2009 - 15 posts - 11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
19 Mar 2011 - 14 posts - 9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
Adwww.hotpoint.co.uk/SparePartsrating for hotpoint.co.uk
Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
Price Match Guarantee · Spend £35 & Save £5
My name is Peter. I am a retired field service appliance technician.
After review of your washer components, there is a strong possibility that you have a bad electronic control board. You have two control boards, one is for the motor and one for the other functions.
Washer electronic control board for Kenmore Elite Washer model #11021062001 Electronic control board 8571359 is the circuit board that manages the washer's functions, such as filling, washing, draining and spinning. It sends voltage to the drive motor and other electro-mechanical component.
Cost: $218.00
If you elect to replace the board make sure you ground yourself by rubbing your hands on something that is bare steel. Static electricity will knock a board out.
All appliances with electric control boards should have a surge protector. You can purchase a wall socket surge protector for $20-25.00. It is a good investment considering how expensive control boards are.
Rule of thumb; "If the unit is either 7 years old or the cost of repair is 1/3 or more of the original price, purchase a new unit.
Consider it purchasing a new unit, stripping your existing unit for parts to sell on e-bay. You will make a little money and save others expensive parts cost.
code E1 Main electronic control board failure Unplug the washer. Check the wiring connections on the main electronic control board in the console. If the wiring connections are sound, replace the the main electronic control.
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
hi if the product number is914512801 followed by 00 the electronic is £170 and has to be programmed on the machine (not do it yourself repair) . if the product number is followed by 01 the electronic is £82 and does not need programming as it is pre configured This you can do. I would look for earth faults on the heater or motor or short circuit on the pump or solonoid valves before changing the electronic . hope this helps.
Check the Water Indicator (WI).
When you think it should be enough water, unplug WI connector from control board and check if on WI connector is closed contact (WI written on the control board housing). If not, try with some more water. And so on. When too much water with no contact on WI, it is the one to be replaced by new one.
NOTE: by every check UNPLUG the machine
I had a very similar problem with my Oasis He Washer 110.27087603. The machine was randomly cycling through different water temperature indication lights. It would repeatedly beep and not allow a wash cycle to complete. Fixya.com alerted me to the "upgrade" to the electronic control W10112112 to W10189966. My machine was scheduled service and a Sears tech replaced that board. My problem with random cycling continued and the tech stated the touch panel electronics; part # 8564392 would fix the problem. He said one of the microswitches on the panel was probably stuck and not allowing the machine to enter a wash cycle. I found the 8564392 panel at http://www.prosupplyco.com/search.aspx?find=8564392 for a very reasonable price. Realize that Whirlpool parts are Whirlpool parts and Sears doesn't hold the only key to them.
What a very poor, casual answer.! I have to complain further.
