Question about HP Pavilion DV6500T PC Notebook
HP 6500 laptop media bar not lighted and unresponsive. No sound
There is a strip of controls above the keyboard that is normally lit up in blue. I can control volume and manual playback for a dvd. It is now not lit up and the controls don't work. Moreover, there is no sound, even though the speaker icon shows sound (i.e. it's not on mute) and the device manager shows everything is working. When the headphones are plugged in, I CAN hear sound. So, no sound without the headphones plugged in.
  • 2 more comments
  • alexjoss May 16, 2009
    Yes assuming you mean thru windows sound control. Also i already installed the software you recommended. Could some hardware have been unplugged?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    I believe there is a strip cable underneath the media bar that connects to the motherboard. The media bar should come off all in one piece, you may have to pry it off. When you do, try reseating the cable and then turn the laptop back on.
  • Ben Wabnick
    http://h10025.www1.hp.com/ewfrf/wc/softw...
    Also try this file at the above link. It is the software for your quick launch buttons, this may activate the media bar.
  • Ben Wabnick
    Can you control sound thru the normal ways thru windows?
Turn wireless
The HP2530p buttons are "touch sensitive" and are located at the top of the keyboard just above the F4 & F5 Keys along the strip where the power switch is. Just touch the orange light and it will change to blue (on) this is the same for the volume screen etc, blue is on, orange is off, Just touch and play
Jul 27, 2013 | HP EliteBook 2530p Notebook
Hp officejet 6500 copier not starting up
Get the Diagnostic download for your 6500 from HP.com. It will trace the problem for you. Check you power supply to see if it is operational. Press all connections in tight.
Feb 04, 2018 | HP Officejet 6500 Wireless All-in-One...
Enable wireless on Hp probook 6550b
You can enable your wireless lan via quick launch button on the strip , when tapped it will show you blue light when disabled it will show you with orange light, if you see that light is still blue but you are unable to find any wireless network in network and sharing center
simply open network and sharing center > go to change adapter settings right click on wireless network connection and select enable ,
now your wireless should work,
Feel free to contact us if you require more assistance,
Regards, Bilal
Jan 12, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
I have a hp dv6208nr laptop . after pressing the power button the pc starts up the screen is black after a few seconds there are one long beep and two short beeps screen is still black pc acts as if it is...
Graphics card failure. There is no cure for the problem at HP but see if your model is on recall (as some are) or phone HP to find out if you can get a free repair for their poor quality cards
Sep 11, 2010 | HP NB199UA Pavilion Notebook
Can't find the button to connect and disconnect the wireless internet connection on our HP laptop: Pavilion dv7-3065dx. Somehow it got turned off and we don't have our manual with us.
Your wireless command switch is not a physical switch. It should be one of the touch sensitive contacts on the media control bar (right above the keyboard). It should look like a little straight up line with comas coming from the top (the idea being a tower sending out radio waves). You should just be able to touch it with the pad of your finger and activate the wireless which will then light up blue like the other "non" buttons.
Regards
Jul 13, 2010 | HP Computers & Internet
Our HP Pavillion dv8000 just recently started having problem with keyboard. No Virus. Caps Lock light will not go on (frozen) and "s" key does not work. Sometimes the keyboard properly- sometimes it...
Clean the keyboard wiith a compressed air can, if that doesn't do the trick try a usb keyboard, if the external keyboard works well then you need to replace the laptops keyboard.
May 13, 2010 | HP Pavilion dv8000t Notebook
My volume scroll does not work on hp laptop? not had it long, can anyone help>
If you are talking about the quick volume buttons above the keyboard then it could be two things. first the cable that goes from the mother board to the control is bad or the volume control part under the plastic has gone bad. If it is any of these then the buttons should have stopped lighting up blue. If they have stayed lit up then it is a software problem.
Feb 10, 2010 | HP Pavilion dv4000 Notebook
Switch cover on HP dv9913cl laptop does not come off
DV9000s has I believe 6 small screws holding it in place. The keyboard has three, one in the wireless compartment and two in the battery compartment. The six small screws that hold the power and media plate on is in the battery compartment. Pry up the power bar with your finger tips starting on the right side and work your way over to the left. The movement is going to be restricted because of the power and media cables attaching it to the motherboard but it will give you enough room to pry the keyboard up and move it out of the way. You do not have to remove the power strip if you don't want to, if you do want to move it, the flat cables should be disconnected at the motherboard, just pull them free of the sockets, there is not lock tab like there is on the power strip itself. There is a small black plug on the power strip on the left side where the flat cables attach, this just pulls free of the strip.
Oct 20, 2009 | HP DV9913CL-RB Entertainment Notebook
I have an HP Pavilion 9000 that was working just fine. We powered it down for the day and when we went to start it up the next day it would not start. Blue light is lit where power supply plugs into...
That a nice computer you have there. Based on your description, my guess is you have a bad power supply.
About a $300 fix if you send back to HP. Which is what I had to do a while back.
Oct 20, 2009 | Compaq Laptop Keyboard for HP Pavilion...
Sometimes the keys that have white and blue writing on them will only respond blue. How do i get them to respond as white instead of blue keys?
You have a FNC key on your keyboard. Since it is a laptop, your keyboard can not have all the keys that a normal keyboard has. This is handled by making some keys perform two or more functions. Thus, the alternate key use if the blue keys (function key is depressed). You will pribably find that there is a light labeled as FNC where you see your caps lock, num lock etc.. it sounds to me that you have your keyboard in alternate function mode so that the keys are performing the alternate functions (probably the numeric keys if it is a normal configuration..).
Thanks!
Stan Skaggs
Oct 19, 2009 | HP Pavillion G50-111NR Notebook
HP Pavilion DV6500T  PC Notebook Logo
408 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
