Question about GE Washing Machines
WANT TO BYPASS THE LID SWITCH, HOW DO i DO THAT?
THERS NO REAL PROBLEM, i JUST WANT TO WATCH THE AGITATOR TO MAKE SURE THAT IT IS OPERATING, i HAVE THE FEELING THAT IT IS NOT, BECAUSE WHEN i LIFT UP THE LID i DONT SEE ANY MOVEMENT.
  • COACH_COWBOY May 16, 2009
    GOOD ANSWER FOLLOWED THE INSTRUCTIONS, TURNS OUT THE SWITCH IS THE CLOSED TYPE.
    MAHALO,
    COWBOY
  • GE Master
  • 19,396 Answers
There are two kinds of lid switch. One operates when closed, and one when circuit is open.
You need use a multimeter to find out if the switch is open when on (with no electricity on wire when the lid is closed), or closed when on (you get electricity when lid is closed).
If circuit is open when on, then break the contact cutting the wire. If switch is closed when on, then jump the two wires together.
Do not operate the machine for a full cycle with lid switch on, be sure that you know what you are doing and follow all safety rules.
Posted on May 16, 2009
I have a Kenmore washer model 110.26832690 that will not spin. It will fill up, agitate, but on spin cycle it will only drain. Does this sound like a bad lid switch or a bad drive adapter? From what I've...
if it agitates correctly,then its likely your lid safety switch, agitate and spin cycles are reversed by the motor during the cycles of agitate and spin,some units are wired to not operate on either agitate or spin,but some will operate on agitate with the lid open,but not on spin,open control panel and bypass the lid switch and this will tell you before you tear out the direct drive pump,motor and get to the d.d. coupler at the transmission
Mar 20, 2011 | Kenmore Washing Machines
Washer will fill,drain,agitate but won't spin. bypassed lid switch to eliminate it as possible problem any thoughts?
you have done well to bypass the lid switch now check to make sure the water level indecator is shutting off.
Jul 27, 2010 | Whirlpool LTE5243D Top Load Stacked...
It fills up and won't agitate. It seems taht
not advisable to bypass switch this is a safety device to prevent injury your switch is adjustable or repairable by lifting the hob locating switch and doing necessary repair or adjustment please do not bypass think of your safety and the safety of others
Nov 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer doesn't agitate or spin, it just drains and fills up
That sounds like your lid switch. The lid switch on most models of top load washers will be bypassed on fill and drain. As a safety the lid must be closed for agitate and spin.
The lids switch is a pretty easy part to replace and is inexpensive.
Oct 02, 2009 | GE Washing Machines
Washer not agitating,it doesdrain but does not agitate
Hello
You need to check and test the lid switch, The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine. For this reason, the lid switch should never be bypassed.
Test the switch for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Inspect the motor coupler,
Inspect the driver belt (belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
Inspect the agitator
Inspect the pump coupling
Test the water level switch
Regards
PCmania
Sep 26, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Moffat MW600L Washing Machine will not operate
The lid switch may be bad or the part that strikes it may be damaged. There should be a hole that is covered under the lid. You can use a pincle to push it down and see if the wash cycle starts. If it does the part on the lid that presses the switch may be damaged or missing (some were plastic). If it does not operate. You can unplug machine and remove the switch wires (under the top of the washer)and install a (test) jumper wire to connect both wires from the switch. Try to operate again. If it operates now you need a switch. I was unable to find your mod. in my manuals...
Aug 05, 2009 | Washing Machines
The washer turns on, fills with water, then stops. Agitation won't start unless you slam the lid or sometimes if you "nudge" the setting forward and then pull out and then in.
Sounds like door switch may be failing, or the wiring between door switch and timer has loose connection. You can replace the switch or check ther wiring, or bypass the door switch circuit by jumping the leads at the timer
Aug 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
Washer will not spin
Check your lid switch with a screwdriver pushed into it but, be carefull the switch will now not prevent the tub from spinning
May 29, 2009 | Washing Machines
No spin
Cowboy, make sure the lid switch is operational. If it is and you can get it to spin in the test mode but not in the regular cycle, sounds like a control board issue to me. Catriver..post back.
Sep 25, 2006 | Kenmore 42182 Top Load Washer
Washing Machines Logo
791 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
