Question about Garden
I AM A LITTLE DISABLED AND NEED ASSISTANCE WITH KNOWLEGE ON HOW TO REPLACE WEEDEATER LINE IN HOMELITE WEEDEATER
#1 Taper
  • 1040 Answers
SOURCE: starts but when throttled continues to die
You have carburetor problems. You will need to take the carb. off and disassemble. Clean the carb. with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb. to make sure it isn't clogged. The smallest of particals can cause the carb. problems. Check the gaskets as well. Depending on how old your trimmer is, you may have to buy a carb. kit and replace the Needle valve, appropriate gaskets, diaphragm, and small screen.
Jim
Posted on May 30, 2009
canbruce75
  • 1776 Answers
SOURCE: Gas/oil mixture for my Homelite Trimlite weedeater 25 cc
50:1
Posted on Jul 12, 2009
jimmy nutron
  • 132 Answers
SOURCE: Can't get weedeater spool head loose to change the line.
there is three types of heads push, screw, and snap. The screw type have a big ball looking thing on the bottom that when pressed lets the line out. the snap kind are verry distinctive they slid in and two tongs snap in to place you will be able to see them on the out side. the push head just push in and turn.
Posted on Jul 23, 2009
  • 474 Answers
SOURCE: carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Posted on Dec 25, 2009
  • 3074 Answers
SOURCE: model ut21004 homelite gas weedeater want stay
fuel issue, look for cracks or holes in the two lines from tank to prime bulb, check prime bulb, adjust/clean carburetor, may also need to check filter inside tank it is connected to the bigger of the two hoses. Tim
Posted on May 30, 2011
Primer bulb not filling
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
May 02, 2014 | Homelite Mighty Lite Lawn Trimmer
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Primer does not work
Homelite Tune Up
Apr 22, 2014 | Homelite Mighty Lite Lawn Trimmer
Bulb will not prime
Homelite Tune Up
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Jul 23, 2009 | Garden
Won,t prime.Little bit of gas goes into priming ball and stops
You probably have a cracked or broken fuel line. It would be a good idea to replace both of them while you are at it.
If you need further assistance, just let me know.
Jim
Jun 12, 2009 | Homelite Garden
Starts but when throttled continues to die
Jim
May 30, 2009 | Homelite Garden
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
