Question about Braun WK200 AquaExpress Electric Water Kettle White Electric Kettle
Braun electric water heater lid came off along with spring parts, all intact. How do I re-assemble it? Manual? Schematic available?
This is the solution for the BLACK Braun electic water heater, so you must adjust the color to fit if yours is another color.
First take the 3 pieces that go inside the top. Two look like a "Z", and the other is the square, white doo-dad. Take the square piece and slip it into the slot with lid open. YOU CANT PUT IT IN FLAT UNLESS THE LID IS OPEN! Make sure that you can put it in FLAT. Once it is in flat, take it back out. Now you have the 2 "Z" pieces. Fiddle around with these pieces until you learn how to put them in together so they will fit together. This may take several tries. There is a piece that acts like a pivot. Now take all 3 pieces out. The trick is not to put the 2 "Z" pieces in together. You have to figure out what Z-piece to put in first. Then put the rectangular white piece in, and then the other Z-piece. This all must be done with the lid OPEN, otherwise the rectangular piece will not lie flat. Make sure the little spring inside this rectangular piece it put in properly - it should be against the little black doo-dad on the lid. If everything is sitting happily together, you should be able to snap the other black part onto the lid, and close it successfully.
Posted on May 17, 2009
I'm looking fr both the bowl & lid fr my 4259
The bowl and lid are no longer available and our out of production, at least Australia/New Zealand. Braun Food Processor Bowl BR67001126 Buy Online Need Part
Jun 11, 2014 | Braun K 750 CombiMax Food Processor
The washer work but stop along the way,ie unable to complete the circle
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Washing Machines
Braun 4169 user manual
i could not find a user manual but follow this link to a schematic of the machine and its parts numbers hope this helps you
http://www.1800parts.com/images/1800Parts/English/products/standard/4169-Schematic.pdf
Sep 17, 2012 | Braun Hand Held 120 W Mixer Model 4169 In...
The spring that turns off the power in my Intermatic WH21 timer is broken. Where can I buy a new spring?
Parts are not available for WH21 240V water heater timer.
Timer has 1 year limited warranty.
http://www.intermatic.com/customer%20service/frequently%20asked%20questions.aspx
WH21 is rated for 25Amps and works on water heaters up to 4500Watts.
Look at label on side of tank to see wattage.
WH21 is SPST and turns off one hot wire to water heater.
I ran a business for many years.
Cost of stocking, organizing, and shipping parts is near same cost as new timer.
Following page shows selection of replacement timers:
http://waterheatertimer.org/Boxtype.html
For example, I have tested WH40 and T104 and other timers that show on page.
Trippers and motors are available for Intermatic box timers WH40 and T104, so you can maintain these specific models for many years.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
WH40 and T104 timers are SPDT and turn off both hot wires to water heater.
Both timers will work on any wattage residential water heater
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
Feb 18, 2011 | Electric Intermatic Wh 21 Water Heater...
I have a Braun KF580 Coffee Maker. The lid that covers the water reservoir has a broken "nub" where it should fit into the hinge. The number on the lid is >PR< N2 1 04 and under...
I have found two sources for Braun replacement parts; here and here.
Neither of these list the cover of the water reservoit as an available part.
Suggest you send an inquiry to each of these sites to see if this is a part they could source for you.
Feb 05, 2011 | Braun AromaDeluxe KF 580 Coffee Maker
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
Problem with shaver
are you talking about springs under the center cutter bar between the foils? If so, you will need a new foil and cutter set. It is available at shaveroutlet.com with link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
Or maybe you refer to a spring that goes to one of the clips that hold the foil assembly to the pivoting swivel frame. If so, you will need the part linked below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Jan 14, 2010 | Braun 360┬░ Complete 8985 Electric Shaver
Braun 5750 needs new battery -this i think is only available with circuit board - where can i purchase or get this shaver repaired
If you are handy and know how to solder (and have the tools required), you can probably do the replacement yourself.
At the bottom of the razor are two plastic caps on either side of the charging port, you'll need to pry them out with a sharp pick or thin knive tip. Once removed, you can get to the screws that hold the front and rear case halfs onto the main shaver chassis where the PCB with the rechargeable battery is soldered onto the board.
Unsolder the battery and solder in the new replacement battery and put the case back together, making sure all the parts are in the correct posistion, and you're ready to recharge the shaver and start shaving again. If you're going to replace the internal board, it's just a matter of simply replacing the entire board and orienting the motor assembly connection onto the new PCB.
To find your replacement parts or batteries, try Electric Shaver Service. They also do repairs, so you might want to get an estimate if you don't want to do the repair yourself, etc. They're reliable and fast in getting shavers repaired and back to you quickly. 1-888-476-1785
Here's a link to the page with your battery on it and the toll free number to call for estimates too.
www.electricshaver.com
Hope you find this Very Helpful and best regards!
Oct 12, 2009 | Braun Health & Beauty
Kitchen Appliances - Others Logo
342 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
