Question about Homelite Mighty Lite Lawn Trimmer
Pull cord all the way out, and will not recoil
I am so mad! The pull cord on my homelite trimmer pulled its entire length out, did not start, and now it wont recoil! I there a way to fix it? Or should I just try to take it apart?
Cathy
  • 1 more comment
  • Anonymous May 18, 2009
    Same thing.
  • Jay Frederick May 23, 2009
    Same.
  • Anonymous May 24, 2009
    same problem
  • 15 Answers
And like Jimmy said, "loosening" the cowling will allow the rope spindle to retract past the locking arms that meet the spindle.
Sometimes, remember the opposite is true (even if brand new).
When the spindle is TOO loose, it will sometimes get hung up on those same locking arms.
Most of the time, that is why a "smack" to it's face will work wonders. That and just tightening up your mounting screws.
I just got done with my Zip Start, and that was part of (many) the problem with it. Too loose (plus the rope broke, TWICE).
Posted on May 28, 2009
  • 4 Answers
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
Posted on May 25, 2009
Coleman powermate vangaurd 9hp. how long is the pull start rope?
no set length on any recoil repair
old one will be stretched or broken
melt cord end for ease of fitting and no fraying through holes
and finishing knots
feed one end into recoil internal through outer and inner casing
then knot
set recoil spring into correct position and tension
cord is at least three times around recoil
leave excess cord out for pull handle and later adjustment
then cut .. melt end .. feed thought pull handle
then adjust as you test recoil off the motor
then fit to motor.. pull a few times
and final adjustment of cord length at the pull handle
Oct 13, 2016 | Coleman Electrical Supplies
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
Pull cord wont recoil homelite xl 12
You will need to take the cover off to get to the recoil, then remove the pull handle do not let go of the cord! Now ease the cord into the reciol but do not let the cord go, now while holding the cord and the recoil spool rotate the spool 1 revelution clockwise, send the cord back up through the case hole and through the pull handle tie the knot in the cord and replace the case if this still isn't enough repeat the process.Dennis
Oct 31, 2012 | Homelite Garden
Gentlemen, I have a Mighty lite Trimmer of which the cord does not recoil. It appeares that the heavy torsion spring bends when cord is pulled and cord stays out instead of recoiling. Where can I get...
I have the same problem....the cord remains out...so I pulled it apart and discovered that the recoil wheel that the cord rewinds onto does not stay where it is supposed to and rides upward catching on the fixings that hold it in place. When i pressed it down the cord retratcts immediatley. Only problem is it does not stay there. It was only used three times.
It has everything to do with being a cheap product. I should have paid a little more and bought a better product. Will not buy homelite again.
Aug 17, 2010 | Homelite Mighty Lite Lawn Trimmer
The pull cord on my homelite weedeater is jamming and not able to pull it all the way... can't see anything that is jamming it and does not appear broken.
Sounds like the cord is caught in a slot on the side of the pulley the rope recoils into. The cover will have to be removed and maybe some additional things but it can be fixed fairly easy with some patience.
Jun 09, 2010 | Homelite Garden
After turning of engine. Starter pull cord stuck.
The recoil spring that rewinds the cord may have broken of pulled loose from its mooring.
Sep 27, 2009 | Homelite Mighty Lite Lawn Trimmer
Replacment of starter pull cord
Remove the recoil cap cut the knot of the old cord off pull out the string. Cut a new cord the same length thread it in and knot it . rewind the spool until the cord in the spool. fish the cord out of the pull hole and tie on the pull handle
Aug 04, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
I cant start it due to the pull cord not coming out further than 5-6 inches??
Sounds like the cord may be wrapped outside of the recoil pulley and may be spinning the motor backwards. The cord can backlash especially if the trimmer kicked a bit during starting.
Apr 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
1,222 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
