Need wiring for honeywell pro 3000 in trane xe1200
Need to wire honeywell pro 3000 thermostat,2 heat/1 cool in a trane xe1200,with original weathertron thermostat
  • 2 more comments
  • mwknitro May 16, 2009
    it is a pro 3000.2 heat/1 cool
    bought from trane
  • mwknitro May 17, 2009
    0=orange,g=green,y=yellow,x2=black,b=blue,t=brown,r=red,w=white.i have it hooked up and ac is working fine.switched to heat and was heating.i dont want to mes something up.anything else to look for or do?thanks for your time
    i have a light brown/tan color wire that comes from thee small circuit board outside.it is marked t1.do you know what that wire is for or does?
  • 252 Answers
The pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
Posted on May 16, 2009
  • HANK MCNEIL May 17, 2009
    what wires do you have and what terms are they connected too on the old stat?
    Can't know for sure w/o seeing how other end is connected , but that sounds right if it was wired right to begin with.
I want to replace a Honeywell Q674L with a Honeywell RTH6580WF for my heat pump. Which wire is the common or C wire?
The old mercury Q674's didn't require a common terminal, so if there's not an extra wire in the bundle you'll have to fish one up... Inside the old Trane, there should be either a terminal strip with the appropriate terminal designations or possibly a bundle of color coded wires. If they are wires, originally they may have had individual tags on them, but if there are none, you're going to have to refer to the wiring diagram for the correct color for transformer common. Or... find the secondary of the transformer to determine the correct one, then extend it up to the new digital stat.
Apr 17, 2015 | Heating & Cooling
Tip
Thermostat Wiring and Terminal Designations
Here is a list of each common terminal and what their commonly used for. Also listed is what colors are commonly used. NEVER ASSUME these are what you have. Verify all your wires by following each to each piece of equipment. This will help you to be able to match your equipment with the terminal.
- R, Rc, Rh Red wire, hot side of transformer
- C various color wires Usually the common side of transformer
- Y Yellow wire, Energizes the compressor, cooling or heating and cooling for heat pumps
- W White wire, heating for most units
- G Green wire, energizes the fan or blower relay.
- O Orange wire, energizes cooling on most heat pump units
- B Blue and sometimes Orange wire, energizes heat on most heat pump units
- B or X Blue, Black, or Brown wire, the common side of the transformer when the t-stat needs a common. Some brands use B as the common (York, GE, and Trane)
- E Pink, Gray or Tan wires, Emergency heat relay on heat pumps with auxiliary heat
- T Tan or Gray wires, For units with outdoor anticipator reset control (Trane, American Standard, GE, and Carrier)
- W2 Pink, or Brown wires energizes second stage heating on 2 stage units
- Y2 Blue or Pink wires, energizes second stage cooling on 2 stage units
- L Can be most any color, energizes service indicator lamp on units that are equipped with that.
The wires that always cause the most confusion are the B and X wires.
Check out the B terminal first. The NEMA standard for the B terminal to be the heating changeover valve but with some units it is different.
Trane, GE, York and some other manufactures which includes older Honeywell thermostats often use it for the common side of the transformer.
“X” Usually is the standard for common, but just like “B” some manufactures do use “X” or “X2” as the terminal for the emergency heat relay.
on Dec 12, 2009 | Heating & Cooling
Honeywell focus pro 6000 thermostat
Right below the w setting on the base plate is the o/b connection. Put the O wire in this slot. During the initial test for heat and cool, the bias for cool for function 2 is 0 and for heat it is 1. To reach the programming press fan and Up arrow. Press next to reach function 2. Be aware the the O wire is energized and operates the reversing valve. Some manufacturers energizes the reversing valve to go into cooling, and some leave it deenergized to be in cooling. Select either 0 or 1 to make the system perform in the correct mode.
Hope this helps.
Jul 25, 2014 | Honeywell Focus Pro 6000 Programmable...
Heat/Cool does not respond after replacing Trane Weathertron BAYSTAT239 with Honeywell RTHL3550
Sounds like you didn't turn the power off and blew the low voltage fuse. Typically a 5 amp blade style (like a car) inside furnace. TURN THE POWER OFF!!
Jul 13, 2017 | Heating & Cooling
I have a honeywell thermostat model # th5220d1003-0636 & need to know what connections to make for gas forced air heat.
This is a Focus Pro 2 heat,2 cool thermostat. If you are connecting this to a single stage(1 heat) residential furnace then your connections are: At the thermostat the R and Rc therminals are internally connected so you can connect your R terminal wire from the furnace to the R terminal at the thermostat(this is your 24 volt supply for both heating and cooling. The W or W1 wire (heating) from your furnace you connect to the W1 terminal at the thermostat. The W2 wire from your furnace(if your furnace is a 2 stage furnace) you connect to the W2 terminal at the thermostat. The G wire from your furnace(indoor fan) you connect to the G terminal at the thermostat. The Y1 wire(cooling) from your furnace you connect to the Y1 terminal at the thermostat. The C wire(common or neutral) from the furnace you connect to the C terminal at the thermostat.
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Dec 28, 2008 | Honeywell Electronic Programmable...
My Honeywell PRO 3000 thermostat is not activating the cooling system when prompted.
R==power w=heat y=cool g=fan remove the front cover to reveal the 4-wires and take a jumper wire from r-----to ---g ,to see if the fan operates. Then take the jumper wire from r----to--y, to see if the cooling system works outside, because when calling for cool, the thermostat is internaly connected to g--for fan.. Then if it kicks in, then you have a bad thermostat!
Sep 04, 2008 | Honeywell Heating & Cooling
Went from Analog thermosat to a Honeywell 5000 series Digital Thermostat. Worked fine all winter. Now, when I put it on Cool it pushes out Heat. This is a Trane Heatpump.
Look to see if you have it wired correctly with the o terminal be used and then check to see if you have a jumper wire between the Y and W terminal on the Base of the tstat where you hooked all the wires up.
Apr 02, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
1,068 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
