Question about Rockford Fosgate Car Audio & Video
Need a wiring diagram for an accumatch
Need a wiring diagram for a rockford fosgate/veritas accumatch impedance transformer
duby1990
  • 367 Answers
SOURCE: Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Posted on Feb 06, 2009
laseramp
  • 309 Answers
SOURCE: 401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
the problem is mostly with your audio side of the amp. i have a 800 Rockford punch series amp hooked in series running at about 15 vdc at 2 ohms stable for now. but the amps left front power side transistors overloaded and smoked out, i will be replaceing my mosfets soon. Now on that side your issues apear to be related to the signal side of the amp. when you hooked the amp up tell me breifly did you hook the rca inputs to the back of the sterio and did you select the proper rca inputs for the amp? also note that amps have a potentiomater that can be tuned up or down to allow the volume or wattage to go up or down threw the system. if it's turned all the way down you'll here nothing. but often you'll get a pop sound or quickly see the speaker move a bit. this indicated the signal side of the amp has signal comming in but no output, just look for a turnable small screw inside the amp top or side. and turn up acordingly. note: to much output will damadge your system. not just the amp. ;)
Posted on Aug 28, 2009
  • 44 Answers
SOURCE: I'm looking for a wiring manual for a punch 150 amp
Follow this link to the downloads page for Rockford Fosgate, you can choose the correct manual there.
LINK
Posted on Sep 25, 2009
SOURCE: Error code E 03 on a Rockford Fosgate 6 disk CD player
I am having the same problems. Did you ever figure out what was wrong?
Posted on May 04, 2010
SOURCE: nissa titan rockford fosgate 6-cd changer not working
i have the same problem. it started today. any luck in finding a solution?
Posted on Jul 28, 2010
I have a rockford fosgate prime r500x1d amp and it made a weird noise and then it smoked but the blue light stayed on and it seems to be working fine ,could the thermal protector have burned up?
There is no chance that the thermal protection burned up and the unit still works. The thing you need to find out is why it did that. Check the speakers and the wires for shorts and proper impedence.
Jan 09, 2015 | Rockford Fosgate Car Audio & Video
Protect mode?
You added speakers in parallel which reduced the effective impedance to to a value low enough that your Rockford Fosgate amplifier had to enter protect mode to prevent damage to its output stages.
Jan 22, 2014 | Car Audio & Video
Rockford fosgate p4004
You need to check the ohms on your subs an amp . try unbridgen the amp . Go to Rockford Fosgate dot com on the amplifier wiring diagram hopefully that helps 6_28_2013_8_51_12_am.jpg
Jun 18, 2013 | Audio Players & Recorders
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
Im looking for the wiring diagram for the rockford fosgate 4000.1bd
Did you try contacting Rockford Fosgate? They have a website rocfordfosgate.com.
Apr 28, 2011 | Rockford Fosgate 40001BD Car Amp
Overheating amp problem...easially fixed, i think....
depends on the sub rating.
if subs are 2 ohm rated you can ONLY get 1 or 4 ohms..
2x2=4ohm series
2/2=1ohm parallel
if subs are 4 ohm rated wire in parallel
4/2=2ohm
look it up google for diagram if you need one.
Aug 06, 2009 | Car Audio & Video
Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
Rockford Fosgate 120a2 amp
You can get it from Rockford.
Let me know if you need any help repairing it.
Aug 19, 2008 | Rockford Fosgate 100a2 Car Audio Amplifier
Sub hook ups
There's a lot more factors involved than that.
  • Power capability of the subs
  • Type/size of the sub box
  • Allotted space in the vehicle for the sub box
  • Voice coil impedance of the subs versus the capability of the amp
  • Etc.
Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Car Audio & Video Logo
64 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
