Question about E-Machines eMachines Desktop PC
Emachine desktop is hanging at the intial startup screen
At startup, the machine will start to the screen that allows to hit F10 for or F2 for bios, but will not pass, and neither F keys work.
  • David Weaver
    David Weaver May 11, 2010
    sounds like a lock up on boot. I would certainly try a some different memory.
    However, its no big secret Emachines has the worst motherboard issue of all PC's, so having it tested by a repair professional, may be in order.
  • 3,267 Answers
Most probably the keyboard has konked out. Simply try the same with a working keyboard & mouse, 'cos it seems to get stuck during POST(power on self test) due to one or more components malfunctioning. If you had removed the PS2 jacks recently, check for bent pins too.................sodeep
Posted on May 16, 2009
Emachines Em250 has a blinking cursor after bios menu
May be a bad HDD. Can you access the recovery software at boot? Remove ALL media, DVD, CD, USB. Shut down, unplug, remove battery, plug in, with one habd push the on/off button, with the other press the Alt and F10 keys repeatedly. Here's the procedure: http://support.gateway.com/emachines/desktop/2009/gateway/dx/dx4300/DX4710faq6.shtml
Jan 17, 2013 | eMachines eM250-1915 Netbook
It wont start
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Aug 02, 2012 | E-Machines eMachines Desktop PC
My computer is at e screen, f10 and f2 what should i do
it should exit that screen in a couple seconds then boot into you operating system. (side note; f2 takes you to the BIOS settings page i recommend not tinkering with that and f10 takes you to the boot menu. the boot menu is for choosing which device you want to boot from cd-rom, hard drive, etc.
Mar 31, 2011 | E-Machines eMachines Desktop PC
The motherboard is a MSI MS-7184 in a emachine model t6524 and what is happening is when you turn on the computer, it starts and the lights on the keyboard light up and shut off, then it brings you to the...
Hello
Try f2,then let the screen come up.This is your bios settings,dont change anything.
Next hit the esc key,answer yes or y key.Pc should reboot normally.
If this doesnt work hit the f10 key and select your hdd or hard drive in the options,and reboot.
Apr 29, 2010 | eMachines T6524 PC Desktop
How do I reset bios on emachine d3415
When you say reset...do you mean that you want to restore the bios back to their original factory settings?
That can usually be done from the bios (reboot, press either F2 or F10...the screen that displays upon boot will let you know what to press) ...there should be an option to re-set the bios back to the factory settings.....
But if that is not wat you are trying to do, let me know.
May 08, 2009 | E-Machines eMachines Desktop PC
Stuck on emachine screen
Hi there
Hit F2 on boot up and get into the bios settings, if it lets you in choose default bios settings, save and reboot, see what happens
Good luck
Jan 08, 2009 | E-Machines eMachines Desktop PC
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Startup!
What OS are is on your computer?
joe
Dec 16, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
172 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
